 AE101 POWER WINDOW SWITCH & Door Handle INSTALLED TO TOYOTA REVO DLX
BUSHIDO56
PostSubject: AE101 POWER WINDOW SWITCH & Door Handle INSTALLED TO TOYOTA REVO DLX   Wed Nov 07, 2012 11:27 am
HI GUY'S!
Here's the Picture of my older sister AUV [Asian Utility Vehicle] Toyota Tamaraw FX REVO DLX
My older sister's AUV is the base model with no power window nor central lock. The Installation of
central lock is easy because you can buy any kit that can easily fit your vehicle.
My first attempt to convert the AUV into power window was a completely failure. My friend the
mechanic, cut the front door mirror linkage and welded a motor to it. The Rear door linkage he
bought was I think came from a vios or Yaris model. He installed an unknown model of master power
window switch I think came from mazda 323 and 3 switch from toyota van [i'm not sure what model].
The motor burned up one buy one then the master switch burned up also. Sad
The parts of this AUV are hard to find [second hand, surplus or brand new] and finally I found
a brand new linkage motor for front door. The parts I needed for rear door was AE92 linkage motor
The store owner told me the reason why the motor burned up is because my rear linkage has no
return spring [just like AE92] and the front linkage has no return spring plus the linkage is
welded and might not move properly.
here's the photo of a usual DLX model with wooded door panel [I downloaded this from the internet
because I forgot to take a picture before I modified it]
here's the photo of a much higher grade GLX model [This is My reference of the door with power
window switch]
When I saw this, I thought maybe the AE101 JDM Switch and door handle might fit to REVO
here's the photo of my AE101 JDM door [wood type panel]
The door suprisingly has a hole for this kind of door handle. The Difference of the GLX original
power window switch door handle [front] & AE101 JDM power window switch door is the screw hole. [GLX
has 3 hole while AE101 has 2 hole.
and Here's the new look
3
I also added a side pocket at both sides that came from AE101!
Other specs of AUV:
1 Toyota Tamaraw FX REVO SR SEATS [Sports Runner]
2 Toyota Starlet EP90 Seatbeat [1997] installed to second row
3 Pionner stereo
4 AE101 JDM side pocket [right side front]
5 AE101 PHDM side pocket [left side front]
6 AE101 PHDM Rear Door Handle
7 AE101 JDM Rear Switch with base holder
7 Additional Speaker installed at rear Door
7 4 pcs Speaker Cover [metal hexagon type]
7 3rd Brake Light [Pajero 2nd gen.]
8 Rear water reservoir [Pajero 2nd gen.]
9 Rear wiper motor [Pajero 2nd gen.]
10 Rear wiper arm [Ford Everest]
11 Toyota Hi-Ace Regius Muffler OEM [Power Flow Type]
12 Kia Besta OEM Hub Cap
13 Custom Built Front Grill
So Far So good the system is OK and looks neat!!! Very Happy
PostSubject: Re: AE101 POWER WINDOW SWITCH & Door Handle INSTALLED TO TOYOTA REVO DLX   Wed Nov 07, 2012 7:25 pm
good job bro
PostSubject: Re: AE101 POWER WINDOW SWITCH & Door Handle INSTALLED TO TOYOTA REVO DLX   Thu Nov 08, 2012 11:28 am
very nice work so far bro
BUSHIDO56
PostSubject: Re: AE101 POWER WINDOW SWITCH & Door Handle INSTALLED TO TOYOTA REVO DLX   Thu Nov 08, 2012 3:45 pm
Thanks BRO!!! Very Happy
PostSubject: Re: AE101 POWER WINDOW SWITCH & Door Handle INSTALLED TO TOYOTA REVO DLX   Sat Nov 10, 2012 1:49 am
Nice, I've never seen one of those before!
AE101 Owners Club :: Members Rides :: Non-Corolla Rides-
