 95 Corolla Build
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostSubject: Re: 95 Corolla Build   Fri Mar 21, 2014 3:54 pm
Just gonna leave this here.... ;D
4AGE Silvertop swap in USDM Corolla?
-------------------->Click Right Here<--------------------
turbo? Maybe Comming Soon...
PostSubject: Re: 95 Corolla Build   Sat Mar 22, 2014 12:36 pm
Nice wheels!
PostSubject: Re: 95 Corolla Build   Thu Apr 17, 2014 9:26 am
well guys im just letting you guys know im doing the swap now. 2 weeks ago engine was making knocking nosies and crapped out and stalled so many times that i knew engine swap is gonna happen.
so had it towed to my friends house, taking the old one out, swapping coolant hoses and engine mounts (which i will discuss later). i did some risk taking and got myself an $250 engine harness that was 95% good from a 4age ST. and right now im playing with it and so far its pretty much plug n play. i also belive the RF axle does fit directly to the my corolla (so crossing fingers!!) and i just ordered an 7afe transmount. hopefully i will get it done next week! i will provide some pics later on but right now, the struggle is real....
PostSubject: Re: 95 Corolla Build   Thu Apr 17, 2014 11:48 am
Good man, nothing like biting the bullet and just doing it.
If you need any help just hola
PostSubject: Re: 95 Corolla Build   Sat Apr 19, 2014 8:46 am
Whips looking good man, post up pics so we can follow your swap!
PostSubject: Re: 95 Corolla Build   Mon Apr 21, 2014 9:44 am
loving the rims
PostSubject: Re: 95 Corolla Build   Wed Jul 23, 2014 6:53 am
alright with this long long long build im finally able to show you guys some pics. i was able to get the half shaft bracket and halfshaft and axle and went in smoothly, everything fits, i did run the OEM 4age ST harness i got but found out i was missing some plugs so it wouldnt work, so i got In with Dr. Tweak, sended them my old 7AFE harness and a few weeks later got my new harness in fitted everything in for the swap. as for engine mounts and trans mounts everything almost fitted. except for the auto tragic's transmission mount and the rear engine mount bracket, but thanks to the people here i got the 7a's transmount from my local dealers and fits directly to the silvertops transmission. and as for the rear engine mount bracket i had to do a little modding to make it actually fit on the engine. then there was an a little issue with the AFM. when i ordered the AFM i expected it would come with the appropriate gasket, nuts and adapter, but sadly it just came with the AFM. so i made my own AFM adapter plate. went to a local hardware store auto parts store and another trip to the dealers to pickup the AFM gasket and bolts. got the stuff i need to make it. i only made 2 of them one was just a prototype of what was gonna be the final product. so i went to work on them, while in the build process i realized that toyota uses the same gasket, nuts, and bolts off there AE86 4AGE's. so after the the protype when done being built i went and started making the final product, i ended up using some of the 2.5in aluminum piping off the old CAI and JB welding it a steel plate which later on worked perfect. currently my car is not running yet, im still running into issues. so far im in need of a 5th gen Celica throttle/accelerator cable(89-93), i gotta swap out the brake pedal with the one i got from the junk yard, figure out vacuum lines and fuel return lines, i gotta check the fuel pump (since it was out in the open for the past couple of months), find the signal wire so i can splice into the ECU (yes i know i said i might be splice it some where else but i have a friend that will help me on this on this part since he was originally a Toyota tech), swapping out the old seats with the new ones, make a harness bar, putting the whole interior back, weld a new front exhaust system, straight pipe the exhaust... well thats what i can remember for now but i think im missing 1 or 2 more things that  belong in this pile of stuff i have to do but soon it'll be running! i cant wait for this build!!! stay tuned my friends, pictures are on the way.... probably alot.....
PostSubject: Re: 95 Corolla Build   Wed Jul 23, 2014 12:10 pm
I just see a huge wall of text, no pics lol
PostSubject: Re: 95 Corolla Build   Thu Jul 24, 2014 2:03 am
Sorry it took me a while, i had other activities and stuff yesterday and i didnt come home till 1 in the morning
PostSubject: Re: 95 Corolla Build   Thu Jul 24, 2014 11:04 am
Wow it sure is coming along!! How are the projector head lights holding up?
PostSubject: Re: 95 Corolla Build   Fri Jul 25, 2014 1:11 am
pretty well and when i installed them back on and turn the head lights on, its still as beautiful and bright as i remembered them
PostSubject: Re: 95 Corolla Build   Fri Jul 25, 2014 5:10 am
looks sweet. bet you cant wait to have it finished
PostSubject: Re: 95 Corolla Build   Fri Jul 25, 2014 6:37 am
im Literally dying at this point... lmao
PostSubject: Re: 95 Corolla Build   Fri Jul 25, 2014 8:26 am
congratz man for you new swap! do upload run video after the complete swapping
PostSubject: Re: 95 Corolla Build   Fri Jul 25, 2014 12:34 pm
i will, i'll make one maybe monday or tuesdayif everything goes well
PostSubject: Re: 95 Corolla Build   Mon Jul 28, 2014 6:59 am
waiting to see....
PostSubject: Re: 95 Corolla Build   Sat Aug 09, 2014 5:15 pm
sorry for the long wait but please wait a little longer! in a couple of hours i'll post some pics and some raw gopro footage
PostSubject: Re: 95 Corolla Build   Sun Aug 10, 2014 8:14 am
cant wait
PostSubject: Re: 95 Corolla Build   Sun Aug 10, 2014 4:16 pm
PostSubject: Re: 95 Corolla Build   Sun Aug 10, 2014 8:21 pm
Props bro! So happy to see it finally up and running!
PostSubject: Re: 95 Corolla Build   Mon Aug 11, 2014 5:30 am
sweeet, cant believe its done
PostSubject: Re: 95 Corolla Build   Mon Aug 11, 2014 5:44 am
im still not done yet.....i still need the 2-1 extractor exhaust pipe, straight pipe from the cat back, harness bar, passenger seat should be replaced soon, inner and outter tie rod ends needs to be replaced and an alignment and maybe during the whole changing the tie rods i might aswell make the steering rack ACTUAL manual steering....... then alot of body work...... then down the road get AC to get it working....
PostSubject: Re: 95 Corolla Build   Tue Aug 12, 2014 5:56 pm
It sure is loud lol (no exhaust yet obviously)
And it doesn't seem to run very smoothly, like at idle, is that something you'll work out eventually?
Hopefully you can get that bumper in shape again lol
And I assume there's just nothing left of that c/f hood? oh well
PostSubject: Re: 95 Corolla Build   Wed Aug 13, 2014 2:37 am
i think its due to the fact i dont have the downpipe for the exhaust, and because of that i dont have the front 02 sensor connected thats probably the main reason why...... but if not imma work it out eventually,
the bumper is gonna get in shape again! i know it...
and yea theres barely anything left now..... RIP cf hood
PostSubject: Re: 95 Corolla Build   Wed Aug 13, 2014 9:36 am
RIP hood haha. Can't wait to see more!
95 Corolla Build
Page 8 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
