 Diesel engine losing power
whiteoldcorolla
PostSubject: Diesel engine losing power   Sat Jan 19, 2013 10:22 am
Hi everyone,
Just got back home from a drive and I noticed something frankly worrying.
I've been driving economically on biodiesel recently. Going great, managing 49 MPG no problem.
Today I decided to drive more vigorously than usual, as its been a while and I miss the roar of the diesel engine.
Problem. The moment I floor it it accelerates a lot slower than it used to, but makes a lot of noise. Also, the torque seems to cut out a lot sooner. I have no idea what it could be, it was working fine this morning!
Don't know if I should be super worried or not, I can't afford expensive engine repairs.
Has anyone experienced any similar issues?
Thanks
PostSubject: Re: Diesel engine losing power   Sat Jan 19, 2013 10:27 am
it could be the bio diesel that you are using,
when was the last time you serviced it?
whiteoldcorolla
PostSubject: Re: Diesel engine losing power   Sat Jan 19, 2013 10:40 am
I had the injectors cleaned and the oil filter changed recently, and the mechanic said it was working fine.
I have used biodiesel before this, and it has never happened before. The diesel filter isn't more than a year old definitely.
....could it be the diesel filter clogged up? Cause I remember coming across some research that said that the filter would have to be changed as the biodiesel cleans the fuel tank from muck, that then ends up in the filter....
PostSubject: Re: Diesel engine losing power   Sat Jan 19, 2013 10:41 pm
it could be bro. change the fuel filter again and see if that helps
whiteoldcorolla
PostSubject: Re: Diesel engine losing power   Sat Jan 19, 2013 11:16 pm
I changed the filter this morning and went for a drive.
All fixed Smile The filter was more or less clean but there was like a blackish-brown sediment that I suspect was slowly getting dissolved into chunks. I know this cause it came off in my hands.
Everything is back to normal. I even put the air filter back in so it sounds stock. However, without the air filter it was more responsive and faster Sad
PostSubject: Re: Diesel engine losing power   Sun Jan 20, 2013 12:15 am
ahh i was gonna suggest u to change the diesal filter.....but i gues its fixed..l.
PostSubject: Re: Diesel engine losing power   Sun Jan 20, 2013 2:22 pm
That was easy! Nicely done.
