 DIY Combution Chamber Cleaner
Toysolja
PostSubject: DIY Combution Chamber Cleaner   Wed Jan 23, 2013 9:13 am
Well what u need is a
-10/12 spanner
-Ellen key .. [size is the same as the one u remove spark plug cover with]
-AC Delco combustion chamber cleaner and a Clean Lappie and some -Terps
How u do it is….
The plenum has 5 bolts holding it the u need to remove…
Three on top and on on either side at the bottom…
The one on the bottom @ Break fluid side is hardest/most irritating to remove
STEP 1.
Remove plenum bolts..
STEP 2.
Remove plenum
Once bolts are removed.. the cover comes off
STEP 3
Remove the rubber gasket the run along the outside of the plenum cover
STEP4
Pack all tools away and loose items… grab a video camera and ad go for a quick drive with open throttle…
It sounds k@K sweet
STEP 4 [ continued ]
Allow a few min's of idling to return circulation of oil in the engine then switch off ignition
Please remember to do this with the 20v when ever racing or moering the car..
Could cause car to run a bearing ;( touch wood when ever saying that
STEP 5
Proceed to remove the throttle horns, they are these rubber ones found under the plenum cover
U will need the spanner or this… two bolts per horn, remove one horn @ a time…from passenger side to driver side
STEP 6
Clean the throttles wiping it with clean Lappie and terps …remove all dust and grime in the throttle tube..
Do the same for the horns u removed
STEP 7
Start motor and warm to operating temp…
Then a friend keeps revs or 4000rpm while
you spray the AC Delco into each throttle…we have 4 on the 20v Wink
Continue dong this until bottle completely empty
Please note: the cars zorst fuems will white like someone smokking hullese mandrax in the engine….
THIS IS NORMAL lol
STEP 8
Allow a few mins of idling to return circulation of oil in the engine then switch off ignition
Cant stress this enough Please remember to do this with the 20v when ever racing or moering the car..
Now refit the horns.. refit rubber gasket… refit the plennum cover..
Please note at this time u will be lekker tired… ur almost done hihihih
Make sure all bolts are tight…plenum cover VAS…
STEP 9
Disconnect battery [-] terminal thanks 2zze
Open the fuse box on the passenger side…. Remove the EFI fuse..is a 12v one…
Leave out for 5-10mins to allow ECU to reset itself
Replace fuse once time has expired and close fuse box
LASTLY STEP 10: probably the most important
Have a ICE cold Drink / Beer
PostSubject: Re: DIY Combution Chamber Cleaner   Wed Jan 23, 2013 1:07 pm
Were there supposed to be pictures?
Toysolja
PostSubject: Re: DIY Combution Chamber Cleaner   Wed Jan 23, 2013 3:49 pm
Sorry no pics of this was taken from the another forum
<br>
