 Good cheap brake upgrade
PostSubject: Good cheap brake upgrade   Fri Apr 29, 2011 11:29 am
fitting avensis calipers to corolla ... braking improved
(i read it here http://toyotaownersclub-irl.forumoti...rsion-t429.htm)
went out today and did it... much better braking! got them off a 1998 avensis 1.6.
you need the caliper, the carrier and pads,
carrier and caliper fits straight on to the corolla hub,
corolla brake line bolts straight on to the caliper
you can use the corolla disc
(left is corolla, right is avensis)
(this was just a quick try, the pad sits properly, no touching lol )
Bas Carwash
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 4:45 am
What's the difference between the Corolla caliper and the Avensis caliper? Can't see much difference. Why is it braking better? Seems like a nice upgrade though.
I got some nice brake upgrades as well. I'll go for rear brake discs by using the rear hubs, discs and calipers of the E11 G6R model. It set me back 190 Euro's + 90 Euro's for a overhaul-set.
Freshly overhauled brakes including some paint =>
Other option is an upgrade to braided brake lines. HEL and Goodridge are suppliers for the Corolla. It set me back 80 Euro's and will improve pedal feel. These are the Goodridge ones I'll be using =>
john-905
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 6:29 am
bigger pistons and pads look to be bigger to, sure ishaq will confirm for you though
Bas Carwash
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 6:40 am
It's also possible to mount the front hubs of a Corolla Levin. The one with superstrut suspension that is. It'll give you bigger discs and dual-piston calipers. That'll be my next upgrade if I need more stopping power, for sure.
drew 007
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 6:42 am
^^Thats what some of the lads with the starlets have done buddy and have all said it works a treat, dont the celica st205 ones fit??
john-905
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 6:53 am
im running 205 calipers the stud holes that bolt the caliper on are the same but you need to nut and bolt them on, also the discs will be out i have an st202 5 stud conversion with impreza discs i also have put shims behind the pads as impreza discs are thinner
drew 007
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 6:56 am
^^Nice one bud and what do you think to them??
john-905
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:01 am
very good mate, it also has a st202 rear brake conversion with st202 goodrige braided lines
drew 007
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:06 am
Very good bud, im sure there 4 pots arent they?? as i know they are bigger then the mr2 with haveing more weight to stop etc...
RedTune
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:16 am
nice work mate
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:33 am
exactly what john said.. bigger piston and bigger pads...
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:34 am
iv got the rear disc conversion to put on, just havent had time to actually put them on...
john-905
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:41 am
yes mate they are 4 pots
drew 007
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 7:44 am
Nice one John.
Stefan
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 8:49 am
I have used ehmm....
Fiat Coupe 20v turbo 305mm brake discs.
Alfa Romeo 4 pots Brembo calipers.
Custom self made adapters.
Steel braided brake hoses.
It was a hell of a job, but it was all worth it.
http://www.corollatuning.com
PostSubject: Re: Good cheap brake upgrade   Thu May 05, 2011 8:51 am
wow nice job stefan, any pics?
nilo_bezerra
PostSubject: Re: Good cheap brake upgrade   Thu Aug 25, 2011 2:04 pm
maybe we can use the rear brake, calipers etc from the E130 model?
i will try this and report.
peace
Sorry about my english, will be better with time.
Corolla AE 101 Sedan 1.6 16v 4A-FE
Rio de Janeiro, Brasil
PostSubject: Re: Good cheap brake upgrade   Thu Aug 25, 2011 6:31 pm
That would be great Smile How many pots are we talking about?
ae101ire
PostSubject: Re: Good cheap brake upgrade   Fri Aug 26, 2011 1:22 am
good info
Terryn
PostSubject: Re: Good cheap brake upgrade   Thu Nov 03, 2011 10:59 pm
I'm not much concerned about cheap things when my brakes are concerned,..i feel Braking systems are designed to respond quickly and efficiently to your commands. To do this, they are designed with exacting clearances. Over time and in response to wear, brake systems often lose some of their "tightness". This leads to longer response times, less efficient braking and less bike control.
to avoid this you must take good care of break levers , break pads, brake assemblies. and get it checked after every three months..
PostSubject: Re: Good cheap brake upgrade   Tue Jan 03, 2012 2:15 am
do you think carrier, caliper and pads off a 1999 2.0ltr avensis sr will bolt straight on my 98 e11 sr thanks bridgy
PostSubject: Re: Good cheap brake upgrade   Tue Jan 03, 2012 3:37 am
they should do mate, if you buying them from a scrapyard, you could probably try to fit them to a corolla they may have
PostSubject: Re: Good cheap brake upgrade   Tue Jan 03, 2012 6:15 am
just thought my car hasn't got abs but avensis has what issues would there be if any thanks again bridgy Smile
PostSubject: Re: Good cheap brake upgrade   Tue Jan 03, 2012 7:42 am
shouldn't have any problems.. just dont connect the sensor lol
Yankee
Norway Rep
Norway Rep
PostSubject: Re: Good cheap brake upgrade   Mon Jan 21, 2013 3:32 am
How long would it take to do this upgrade?
Tatsuru Ichishima - "True enthusiasts are really looking for fun, not just speed."
