Today at 4:55 am by shah.saib.7
Our users have posted a total of 42388 messages in 2932 subjects
Go to page : Previous  1 ... 15 ... 26, 27, 28, 29, 30  Next
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 07, 2014 3:08 pm
thanks man  Very Happy
TBH i cant take all the credit, but i know im the only one with a bolt on (OEM everything) 3S swap here in the UK.
About this...and I apologize since I know you have probably covered a lot of these questions already. One day I may very well build a 3s to drop in my Corolla while I play with 20v I have now. But can you answer just a couple questions?
I'm assuming the 3SGTE would fit just as easy as the 3S. Any reason you didn't go that route to start? What gearbox is used with this motor? Is it a 6 speed or do they offer one? What motor mount did you use on the gearbox side? And what axles did you end up using.
thanks for the info
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Nov 12, 2014 2:54 am
yes the 3sgte would fit straight in, i wanted to go down the NA route. I had a turbo and didnt want the same headaches again.
used an S54 gearbox
there was no 6 speed available with this engine, even though im trying to "make" one
gearbox mount was corolla re-drilled
axles - driveshafts? if so then oem st182 (long shaft) and sw20 (short shaft)
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Nov 12, 2014 5:07 am
I don't know why I asked about the 6 speed, we were just discussing that the other day. Do\'oh!
I'm assuming the headaches were caused mostly since it was an aftermarket turbo set up?
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 14, 2014 12:45 am
it was an upgrade from a 4efe to a 4efte, and within 2 weeks the turbo went down, then the bottom end starting knocking, then it just went downhill.. i was on the verge of breaking the car...
then i decided to the sell the fully rebuilt 4efte setup with a 6 speed box, and drop a 3sge in (actually saved quite a bit of money by doing so... which was used on more parts lol)
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 14, 2014 3:48 am
thats interesting bc ive been doing some research on getting a 4efte but most things ive been able to find says just to stay with the 20v.
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 14, 2014 8:23 am
yeah if you have a 20v, dont downgrade to a 4efte .. upgrade to a 3S Razz
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Thu Nov 20, 2014 5:57 am
Haven't taken pics for a while so i thought id go out and take some
DSC_0773_tonemapped by ishaq b, on Flickr
DSC_0789_tonemapped by ishaq b, on Flickr
DSC_0787_tonemapped by ishaq b, on Flickr
DSC_0786_tonemapped by ishaq b, on Flickr
DSC_0784_tonemapped by ishaq b, on Flickr
DSC_0762_tonemapped by ishaq b, on Flickr
DSC_0765_tonemapped 2 by ishaq b, on Flickr
DSC_0767_tonemapped by ishaq b, on Flickr
DSC_0769_tonemapped by ishaq b, on Flickr
And an engine bay pic
DSC_0774_tonemapped by ishaq b, on Flickr
DSC_0779_tonemapped by ishaq b, on Flickr
DSC_0780_tonemapped by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 28, 2014 9:34 am
radiator decided to spring a leak..
20141122_124858 by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 28, 2014 9:36 am
fixed the leak
and then it got quite late and i found a torch and took some pics
20141123_171327 by ishaq b, on Flickr
20141123_171725 by ishaq b, on Flickr
20141123_171732 by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 28, 2014 9:38 am
got a lower temp thermostat .. its OEM which was a bonus Twisted Evil
Old one 82C vs new one 76C
20141126_151814 by ishaq b, on Flickr
20141126_145414 by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Nov 28, 2014 11:19 am
That's quite a leak lol. How did you "fix" that, new radiator?
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Nov 29, 2014 1:10 am
nope. just squeezed the galley shut with some mole grips ;p , was advised this by afew guys who have and modify cars and trucks around my area
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Nov 29, 2014 2:05 pm
22:05:27lol, hopefully it lasts!
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Mon Dec 01, 2014 9:10 am
yeah hopefully lol
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Thu Dec 18, 2014 8:17 am
finally wired up my fogs properly
I used the same principle as this with a few changes
http://www.ae101ownersclub.com/t2482-diy-front-bumper-fog-lights-with-hid-s-corolla-93-97#39180
I used one of these to wire the fogs into the fuses
Screenshot_2014-12-17-15-42-23-1 by ishaq b, on Flickr
my fuse box layout looks slightly different, has a few more additions
IMG-20141217-WA0012 by ishaq b, on Flickr
added the extra circuit
IMG-20141217-WA0007 by ishaq b, on Flickr
IMG-20141217-WA0010 by ishaq b, on Flickr
wired it back to this switch
IMG-20141217-WA0004 by ishaq b, on Flickr
et voila
20141217_155522 by ishaq b, on Flickr
20141217_155507 by ishaq b, on Flickr
20141217_155515 by ishaq b, on Flickr
20141217_155609 by ishaq b, on Flickr
20141217_155545 by ishaq b, on Flickr
20141217_155602 by ishaq b, on Flickr
20141217_155734 by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Thu Dec 18, 2014 11:33 am
Cool pics! I spy some that would look good in the banner Smile
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Dec 20, 2014 4:08 am
hmm i wonder which one?
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Dec 20, 2014 7:30 pm
Any of these I think
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 21, 2014 9:47 am
ill use it for next months competition
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 21, 2014 9:48 am
20141220_065015 by ishaq b, on Flickr
20141220_065018 by ishaq b, on Flickr
20141219_161353 by ishaq b, on Flickr
20141220_064943 by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Dec 31, 2014 8:48 am
Bought some new rims
Ce28 reps
15x6.5JJ
ET38
20141229_185836 by ishaq b, on Flickr
20141230_132834 by ishaq b, on Flickr
20141230_132844 by ishaq b, on Flickr
20141230_132858 by ishaq b, on Flickr
20141230_132913 by ishaq b, on Flickr
20141230_132922 by ishaq b, on Flickr
20141230_132931 by ishaq b, on Flickr
20141230_143821 by ishaq b, on Flickr
my fav shot of them
20141230_155032 by ishaq b, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Dec 31, 2014 10:57 pm
Looks good! Looks like the other rims you had though, so yeah they still look good lol
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Thu Jan 01, 2015 8:50 am
like what other rims i had?
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Jan 02, 2015 12:06 am
Very similar to the wheels you just removed I suppose
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Jan 02, 2015 4:00 am
no, the others were completely different
Page 27 of 30Go to page : Previous  1 ... 15 ... 26, 27, 28, 29, 30  Next
