In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests :: 1 Bot
Go to page : Previous  1 ... 15 ... 27, 28, 29, 30  Next
Currymeister
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Jun 21, 2015 1:40 pm
Hi milb14,
Just a small question about the 3s swap again
I have everything now but wanted to ask one more thing
Did you use the axle bracket that bolts behind the engine to support the drive shaft?
If you did which one did you use ?
Thanks
Regards
Currymeister
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Jun 21, 2015 3:04 pm
I also noticed you kept the welded together shift cable near the gear shifter were the celica cables to long ??
I may attempt to use complete celica shifter unit and hope it's the same bolt pattern to bolt to the floor
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Tue Jun 23, 2015 2:00 am
yes, used the standard celica one.
and yes the celica cables were too long, and the corolla was a little short
the cable will fit the corolla shifter unit
Currymeister
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Jun 24, 2015 12:15 am
Great thanks again
I am staring hard at your gearbox mount and I am trying to see what you modified on it to fit it, or is it not able to be seen from the top?
Of
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Jun 26, 2015 10:41 am
it was re-drilled at the top for the bolts to go through
red089
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Jun 26, 2015 4:26 pm
man i wish i had the tools, knowledge, money and parts to do some thing like this.. kudos sir now i regret not taking pics while the shop was installing the engine on my rolla
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Jun 27, 2015 6:10 am
thanks man, its been a few years in the making... and a lot of help from the AE101 owners from around the world..
do what i did, save for it slowly.. research, research research, then go for it
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Tue Jan 19, 2016 9:43 am
So an update on my car...
Last year in January in went off road due to someone going into the side and causing quite some damage grr (bent wishbone, bent trackrod arm, bent the alloy)
so i decided to take it off the road fix it and all the rust issues and bring it back on the road...
I was also in the process of the building a rocket bunny kit for it.
so i started taking it apart
20150327_121221 by Ishaq bawa, on Flickr
20150327_121242 by Ishaq bawa, on Flickr
20150327_121236 by Ishaq bawa, on Flickr
20150327_121230 by Ishaq bawa, on Flickr
20150327_121245 by Ishaq bawa, on Flickr
20150327_121258 by Ishaq bawa, on Flickr
20150327_121316 by Ishaq bawa, on Flickr
20150327_121629 by Ishaq bawa, on Flickr
20150327_121635 by Ishaq bawa, on Flickr
scrapes off the speedbumps
20150327_121641 by Ishaq bawa, on Flickr
20150327_121643 by Ishaq bawa, on Flickr
all parts being stored on shelves
20150327_122017 by Ishaq bawa, on Flickr
Bought some new wheels
XXR 527 16 x 8.25" ET0
Gunmetal Grey
20150327_122327 by Ishaq bawa, on Flickr
20150327_122607 by Ishaq bawa, on Flickr
20150327_122703 by Ishaq bawa, on Flickr
C360_2015-03-27-13-42-36-550 by Ishaq bawa, on Flickr
20150426_125511 by Ishaq bawa, on Flickr
20150426_134745 by Ishaq bawa, on Flickr
Got a new rad cap cover, it adds some more colour in the bay
20150426_140430 by Ishaq bawa, on Flickr
C360_2015-04-26-14-40-05-487 by Ishaq bawa, on Flickr
MAD MAX look
C360_2015-04-26-14-09-31-081 by Ishaq bawa, on Flickr
Up in the air she goes .. got all the rust cut out
20150514_182601 by Ishaq bawa, on Flickr
20150514_182606 by Ishaq bawa, on Flickr
20150514_182635 by Ishaq bawa, on Flickr
20150514_183105 by Ishaq bawa, on Flickr
C360_2015-05-14-19-24-10-983 by Ishaq bawa, on Flickr
IMG_20150515_083741 by Ishaq bawa, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Tue Jan 19, 2016 10:16 am
skip to present day and due to heavy heavy rainfall, the unit where my car was flooded...
the water went up around 8ft Shocked
so far progress on the car was slow. just changed the alloys colour to candy red.
luckily my car was on the ramp, but that only goes 6-7ft in the air and water still got in Sad
not enough to ruin the electrics but enough to ruin the carpets and seats
rear bumper got swept away, facelift garnish got swept away, lights and other bits got flooded with murky water so i need to clean them up
dropped the oil in the engine and in the gearbox and they were clean, i was so relieved at the sight of that
20151227_120425 by Ishaq bawa, on Flickr
parts i found floating about
20151229_103014 by Ishaq bawa, on Flickr
you can see how high the water got in the bay
20151227_120632 by Ishaq bawa, on Flickr
new colour of the rims
20151227_120736 by Ishaq bawa, on Flickr
decided to move the car that night as there was flood warnings again. so didnt want to risk it
2016-01-01_10-11-18 by Ishaq bawa, on Flickr
20151229_155115 by Ishaq bawa, on Flickr
20151229_155246 by Ishaq bawa, on Flickr
20151229_155249 by Ishaq bawa, on Flickr
in its new home
20151229_181438 by Ishaq bawa, on Flickr
decided to drop a lsd box i had lying around into the car and put a new clutch in at the same time...
yes i am that confident that it will start
20160105_192225 by Ishaq bawa, on Flickr
I got a little bored and decided to make a cold air box
cardboard template
20160107_182124 by Ishaq bawa, on Flickr
20160107_182146 by Ishaq bawa, on Flickr
made it with aluminium
20160108_174640 by Ishaq bawa, on Flickr
20160108_174633 by Ishaq bawa, on Flickr
about to eat the gtr Razz
20160110_145955 by Ishaq bawa, on Flickr
finally managed to get the car started.. process of elimination.. thanks to all the to-yodas that i know
the reason it wasnt starting ....
water in the fuel tank
20160116_171615 by Ishaq bawa, on Flickr
a proper pic of the colour of the alloys
IMG-20160116-WA0025 by Ishaq bawa, on Flickr
an artsy shot
IMG-20160116-WA0024 by Ishaq bawa, on Flickr
the current look of the interior
IMG-20160116-WA0023 by Ishaq bawa, on Flickr
and the engine bay
IMG-20160116-WA0022 by Ishaq bawa, on Flickr
and the video of the car, I had the biggest grin on my face when it fired up cheers
https://www.youtube.com/watch?v=38a0NsGNTCY
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Thu Jan 21, 2016 3:54 pm
ah, so that's why you took it off the road. I didn't know any of this before, so thanks for sharing!
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Thu Jan 21, 2016 7:48 pm
No worries chris
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Jan 23, 2016 5:40 am
Wow, sorry to hear about the flooding. Good thing it was on the lift for sure though and you got it running. I like the color of the wheels and was looking at getting those, but honestly, I felt they were too wide so decided not to.
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sat Jan 23, 2016 6:35 am
thanks bud.. hopefully i can get it on the road and looking as good as it used to
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Fri Feb 05, 2016 8:34 am
starting to look like a car again
Added an over arch on the front bumper along with winglets... and the rims are still too wide
DSC_0892 by Ishaq bawa, on Flickr
DSC_0888 by Ishaq bawa, on Flickr
DSC_0895 by Ishaq bawa, on Flickr
Check how wide these rims are on stock wings cheers Very Happy
DSC_0901 by Ishaq bawa, on Flickr
DSC_0914 by Ishaq bawa, on Flickr
DSC_0917 by Ishaq bawa, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Tue Mar 15, 2016 4:47 pm
It's so cool watching the progress. Similar to the restoration of an old muscle car.  Thinking about aggressive camber or over fenders for those wheels?
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Mar 16, 2016 4:26 am
I knew that style wheel would look sick on these cars, but why they only make them in 8.25 is beyond me. I'm not a big fan of cambering them. You will ruin your tires in no time. My friend has these same wheels on his Miata. He installed some aftermarket fender flares like these and left the camber alone. That's what I suggest, then paint them.
http://www.gomiata.com/mazda-miata-fiber-glass-fender-flare-1990-1997.html
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Wed Oct 19, 2016 1:04 pm
sad about he flooding and delayed your progress man.
How's everything?
Any updates?
Click Here, Grab some Beers & Enjoy My Build...
Arrow  Arrow  Arrow --->Ivan's AE101 20V Black Top 20V 6Spd LSD Build Thread<---
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Tue Dec 13, 2016 8:22 am
Updatessss I know there are a few!!!
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Mon Dec 19, 2016 12:18 pm
Soon sorry Ivan
I will be updating this thread once I get a min
shah.saib.7
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 25, 2016 2:29 am
Can I get details about your Tires size and rim size ? To me they seem perfect!
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 25, 2016 10:30 pm
so the updated pictures,
so the front end started to go back together again, still a little dirty from the floods
20160225_144251 by Ishaq bawa, on Flickr
20160225_152618 by Ishaq bawa, on Flickr
20160225_152659 by Ishaq bawa, on Flickr
20160509_182515 by Ishaq bawa, on Flickr
Engine bay still a mess Rolling Eyes
20160509_182519 by Ishaq bawa, on Flickr
20160509_182533 by Ishaq bawa, on Flickr
Got an lsd for the box
20160509_183625 by Ishaq bawa, on Flickr
20160509_183628 by Ishaq bawa, on Flickr
Going back into the car
20160619_123607 by Ishaq bawa, on Flickr
Straightened up the engine a little
20161204_181838 by Ishaq bawa, on Flickr
Looking more like a car again Twisted Evil
20161204_183948-01 by Ishaq bawa, on Flickr
20161204_184017 by Ishaq bawa, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 25, 2016 10:31 pm
Found some e10 si (3 door hatch) side skirts that i need to mod to fit the car
20161022_145812 by Ishaq bawa, on Flickr
Decided to get some over arches as the wheels were ridiculously wide, and it wouldn't pass an MOT (to allow it to be road legal)....
they are 70mm wide
20161208_160038 by Ishaq bawa, on Flickr
20161208_160104 by Ishaq bawa, on Flickr
Back on the floor after so many months
20161212_170116-01 by Ishaq bawa, on Flickr
20161212_170211-01 by Ishaq bawa, on Flickr
So i found that my rear garnish is broken, on the hunt for a new one now grr
20161212_170238 by Ishaq bawa, on Flickr
and finally the arches mocked up on the car
20161213_135959 by Ishaq bawa, on Flickr
20161213_140010 by Ishaq bawa, on Flickr
20161213_140224 by Ishaq bawa, on Flickr
20161213_140605 by Ishaq bawa, on Flickr
20161213_141006-01 by Ishaq bawa, on Flickr
20161213_141529 by Ishaq bawa, on Flickr
20161213_145918 by Ishaq bawa, on Flickr
20161213_161527-01 by Ishaq bawa, on Flickr
IMG-20161214-WA0002 by Ishaq bawa, on Flickr
IMG-20161214-WA0004 by Ishaq bawa, on Flickr
Next on the list of things to do are:
New front windscreen
Fit the rear bumper back onto the car
Weld the rear arch skins together
Rivet the over arches on
Fit sideskirts
Clean out the interior and start putting everything back together
Overhaul the brakes
Full service
Get it ready for an MOT
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 25, 2016 10:40 pm
Which rims are you referring to?
The current ones are XXR 527 16x8.25 ET0, not 100% on the tyre size
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Sun Dec 25, 2016 10:46 pm
I missed this sound .. (Click the image for the video)
20161213_141204 by Ishaq bawa, on Flickr
PostSubject: Re: ★ The AE-202 Project (Continued) ★   Tue Dec 27, 2016 6:44 am
Really nice to see this is still going strong! Especially after it got completely flooded.... usually that is a complete loss, but you didn't let that stop you!
Page 28 of 30Go to page : Previous  1 ... 15 ... 27, 28, 29, 30  Next
