Go to page : Previous  1, 2, 3, 4, 5  Next
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Sun May 12, 2013 3:08 pm
Here's some better photos I took today. It's hard to capture the shininess of them as it depends on which way the light is coming, but the size is all that matters here Smile
Want JDM parts? Hit me up!
ae101_jp
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Aug 14, 2013 2:13 am
so scott to summarize for the twin pot conversion we need ae101/ae111 twinpots st202 cariers and 275mm disk with 54 or 55 mm center hole???
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Aug 14, 2013 6:55 am
55mm center hole Approve!
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Aug 14, 2013 4:00 pm
i have twin pots with a 260mm disc with no problems
ae101_jp
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Sep 25, 2013 2:28 am
back to this thread again,i would like to ask if corolla zze123 t sport (vvtli) front discs would fit perfectly to our conversion??.....
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Sep 25, 2013 6:06 am
Yes they fit. I believe that's what Ishaq used for his.
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Sep 25, 2013 6:18 am
yeah thats what i used
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Wed Sep 25, 2013 8:22 am
I have also heard that the post 87 MR2 AW11 front disc's are perfect. 257mm.
Just grind your standard carriers back and bolt on the twin pott caliper.
nickpeter
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Thu Oct 03, 2013 1:20 pm
just a quick question i have macphersion setup on ae111 and i want to back to twin pot brakes
so if i use st202 carriers i can use the 275 mm discs yes
but i use the carriers for a ss levin i can only use the 255mm discs yes
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Thu Oct 03, 2013 2:43 pm
Yes, with the ST202 carrier brackets you can use the 275mm discs, but with the AE101/AE111 carrier brackets you can only run up to 260mm discs.
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Thu Oct 03, 2013 2:57 pm
Correct, but I found the post 1987 aw11 MR2 has 257mm disc that will bolt straight up
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Thu Oct 03, 2013 3:15 pm
Levin GT Apex discs are 258mm, with other models only being slightly smaller, so in most cases it makes sense for people to stick to their original discs, unless they want to upgrade to the 275mm discs and use the Celica carrier brackets.
nickpeter
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Thu Oct 03, 2013 8:14 pm
thanks guys for the info i will be using the st202 carrier with the 275mm discs as i dont like the tought of getting discs milled down
nickpeter
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Oct 04, 2013 5:43 am
sorry for another question what brake hoses did ye use as i am being the mac ones wont fit neither will the ss levin ones as there short
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Oct 04, 2013 6:08 am
im using the macpherson ones
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Oct 04, 2013 6:12 am
Yeah just use the McPherson ones. They fit fine, just that the mounting tab which bolts to the strut no longer reaches, so you can either make up a little bracket to bridge the tab to the strut, run braided brake lines or simply just leave it as it doesn't make any difference (except maybe at MOT time when they see it and tell you off Laughing).
nickpeter
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Oct 04, 2013 7:03 am
thanks guys for the help
Millar
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Sun Mar 02, 2014 12:35 pm
Hi guys,
Newbie here. I currently use the Levin brake booster, steel braided lines & Levin twin pot calipers on my setup(I performed a little grinding to fit) on standard 20 valve rotors and they work really well.
After reading this post I'm grateful to you guys because I still have the 275mm rotors and figured I'd have to get a bracket built or something to fit the bigger twin pot calipers but I'm going to be on a hunt to find ST202 carrier brackets.
Many thanks guys,
Millar.
Millar
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Thu Mar 13, 2014 10:14 am
Hey Kiwi-Corolla,
I'm hunting for the ST202 Celica carrier brackets. Could you point me in the right direction to source them?
Or do you know of anyone whom I can purchase them from?
Any input is greatly appreciated.
Millar.
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Aug 15, 2014 12:45 pm
Lets back to live this topic...
I have the same set up on my car, don't remember where but I see or read about the same set up but with bigger brake pads, the ones that take more area on the disc. can't remember if it from Celica or other model but is bigger than the MR2 that we have installed.
Anyone know from what car model they are?
Thanks!
Click Here, Grab some Beers & Enjoy My Build...
Arrow  Arrow  Arrow --->Ivan's AE101 20V Black Top 20V 6Spd LSD Build Thread<---
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Sat Aug 16, 2014 9:55 am
im not sure ivan,
the levin ae111 pads, st202 pads, sw20 pads, avensis pads are all the same / similar
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Sat Aug 16, 2014 1:22 pm
im not sure ivan,
The Box of te pads that come with the Rotors/Discs from UK have a Label that state the following cars use exactly the same pads:
Citroen C5 08+
Toyota Avenis 97-03
Toyota Carina E 92-97
Toyota MR2 89-00
so from this ones are not the options of the bigger ones...
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Sun Aug 17, 2014 8:30 am
maybe the celica st202 ones are bigger then?
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Aug 22, 2014 5:05 am
I just found this online. if anyone know or have other sources we can compare will be great...
http://www.apecbraking.co.uk/catalogue/frictionview/item/669303
http://www.apecbraking.co.uk/catalogue/frictionview/item/668481
Thanks In Advance
PostSubject: Re: Levin SS Twinpots on Stock E10 Mac Hub   Fri Aug 22, 2014 9:34 am
The ST202 Celica pads are slightly wider compared to the AE111 Levin ones, so cover a fraction more of the disc on the inside. The difference in braking performance would be negligible however. When I bought my pads I was deciding between the two types and ended up going for the AE111 pads as they're more suitable for the size/weight of the car.
Page 3 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
