 Calling Diesel Corollas :)
whiteoldcorolla
PostSubject: Calling Diesel Corollas :)   Sat Jun 01, 2013 12:48 am
Hey Guys!
Haven't been active on the site in a while. Who'd have thought that Engineering is such a hard and time-consuming course lol!
So I've been searching like crazy for online specs of the 2C diesel engine, and the 2CT. Reason being that I really want to turbocharge the engine.
As far as I know, the cylinder head, manifold and turbo is all I need with regards to modifying the engine. Supporting mods will obviously come later. Pistons and everything else are the same.
A friend of mine is selling the above mentioned parts, as he had a transit with the 2CT and he bought loads of spares.
What do you guys think? An engine swap would be ideal but its not on the books. Recently had the pump refurbished, cost 180 euro but was worth it.
Any sort of feedback is welcome Smile
PostSubject: Re: Calling Diesel Corollas :)   Sat Jun 01, 2013 10:57 am
best person to talk to about the 2C is shehroze on the site
toyfj45
PostSubject: Re: Calling Diesel Corollas :)   Wed Jul 03, 2013 9:24 pm
If you need to know anything im happy to post it up. I have two projects on the go atm both using the 2c. One is a 69 corolla that will have a hot rod 2c with bigger pump and either a supercharger or hybrid turbo or both undecided yet as im only part of the interested party.
My new daily is a jdm 94 ce100 which I will be hotting up soon. I did get a turbo for it that I was gunna rebuild but now im undecided on it so im back to plotting data onto maps (not real fun).
If its small boost your looking at 8-10psi and your engine is ok then just build a manifold to suit a turbo, and play with fuel.
94 ce100 jdm daily
73 fj45 offroad weapon getting the hj60's heart
69 ke10 big project - regretfully sold
whiteoldcorolla
PostSubject: Re: Calling Diesel Corollas :)   Thu Jul 04, 2013 4:39 am
Ah cool. DO you know if the manifold off the 2c-t is a direct replacement or do I need anything else?
PostSubject: Re: Calling Diesel Corollas :)   Thu Jul 04, 2013 7:22 am
i think its a straight swap
toyfj45
PostSubject: Re: Calling Diesel Corollas :)   Thu Jul 04, 2013 10:34 am
Yep it is but your limited to using a ct9 or ct12.
94 ce100 jdm daily
whiteoldcorolla
PostSubject: Re: Calling Diesel Corollas :)   Thu Jul 04, 2013 7:45 pm
Ah cool I'll look into it. I heard from a reliable source that I'd need the cylinder head and the manifold off the 2ct... I think it really is a question of finding one and trying it :/
toyfj45
PostSubject: Re: Calling Diesel Corollas :)   Thu Jul 04, 2013 9:15 pm
My fsm shows them as one and the same from 1c through to 3c. Ill check the parts data base though. It all comes down to how much boost you want to run. If your looking at low boost then you really dont need to touch your engine unless its sad. If a compression test shows all 4cyl to be good then strap on the turbo dial in more fuel and leave it as done. Although the 2c is mechanically injected it lacks a boost compensator so once dialed in there will be a small puff untill the boost builds.
One thing id suggest is if you can cap off the egr, that was the first thing done to my 2c although egr wasnt required for a 94 diesel here.
94 ce100 jdm daily
whiteoldcorolla
PostSubject: Re: Calling Diesel Corollas :)   Fri Jul 05, 2013 10:38 pm
Thats great news! Finally hahaha I needed a straight answer like that! Best part is when I go for the VRT (Vehicle Roadworthiness Test - our version of an MOT) I'll just switch everything back to standard to avoid hassle... I'll start looking for the parts then. I should be able to find some parts as here the 2C-T is put in those old BMWs for drift and economy in street cars. Anyway. THANKS!
PostSubject: Re: Calling Diesel Corollas :)   Sat Jul 06, 2013 2:34 am
I don't know about 2ct but know a lot about simple 2c..you said u had ur pump serviced...what size nozzles were used...were they 31 or 32 or other size...32 is stock size I have 31
Flat White
PostSubject: Re: Calling Diesel Corollas :)   Sun Jan 11, 2015 7:47 am
Hey dieselists. Can one of you guys tell me what model gearbox is fitted to diesel AE101s?
PostSubject: Re: Calling Diesel Corollas :)   Sun Jan 11, 2015 12:21 pm
S-series, from memory S50?
Flat White
PostSubject: Re: Calling Diesel Corollas :)   Mon Jan 12, 2015 12:48 am
Ooh similar to that used on the 3S engines then. Having read loads of build threads I've not seen it done but would this in theory make diesel mounts the way to go for a 3S-GE conversion? Or Am I missing something? Smile
PostSubject: Re: Calling Diesel Corollas :)   Tue Jan 13, 2015 9:25 am
the gearbox mounts maybe, the engine mounts probably not
Flat White
PostSubject: Re: Calling Diesel Corollas :)   Tue Jan 13, 2015 12:37 pm
Are the front and back mounts not also on the gearbox? Front mount certainly is on my car. I thought the rear too which leaves the Rav4 mount as you suggest. Have found an excellent online resource for drawings with part nos for all Toyotas. Will post a link soon. Confirmed the 2.0 diesel gearbox is the same casing as that fitted to celica so hopefully will make the swap easier Smile
PostSubject: Re: Calling Diesel Corollas :)   Tue Jan 13, 2015 10:28 pm
front and rear on mine are corolla / celica mix.. they line up
the cambelt side (drivers side) is the rav4 mount
