 4A-GE 20V idling problem
affliKtd
PostSubject: 4A-GE 20V idling problem   Sun Jul 07, 2013 9:06 pm
Hey guys,
My blacktop is currently having some idling problems after I reconnected the battery after installing an audio amplifier. It has started to rev at idle up to about 2 - 2.5k for a few seconds then will drop down to about 1 - 1.5k before raising again.
I have no idea what it could be and wondered if anyone else could shine some light??
I hate speedbumps.
PostSubject: Re: 4A-GE 20V idling problem   Mon Jul 08, 2013 1:19 am
is your battery ok..and does the idle.problem still exsists whe. the amp is disconnected......also is the grounding ok
PostSubject: Re: 4A-GE 20V idling problem   Mon Jul 08, 2013 7:21 am
Have you tried disconnecting the amp to see if it returns to normal? Maybe the amp is wired wrong.
PostSubject: Re: 4A-GE 20V idling problem   Mon Jul 08, 2013 9:04 am
Make sure it has a good earth to bare metal, failing that make sure all yours wires, terminals etc are all nice and tight too.
PostSubject: Re: 4A-GE 20V idling problem   Mon Jul 08, 2013 3:01 pm
have you removed one of the vac pipes
affliKtd
PostSubject: Re: 4A-GE 20V idling problem   Mon Jul 08, 2013 11:03 pm
Okay... It randomly just fixed itself.
I'm going to install a vacuum block at some point soon
I hate speedbumps.
PostSubject: Re: 4A-GE 20V idling problem   Tue Jul 09, 2013 9:32 am
Oh, I guess you disconnected the battery when installing the amp? It sounds like the ECU got reset, and it had to do an adjustment to relearn the right settings.
affliKtd
PostSubject: Re: 4A-GE 20V idling problem   Tue Jul 09, 2013 9:07 pm
Yeah that's what an audio specialist suggested. Thank toyota for self learning ecus... Even seems to be running better than ever now
I hate speedbumps.
