  corolla rear disc brake coversion
Go to page : 1, 2, 3  Next
emmet.harten3
PostSubject: corolla rear disc brake coversion    Thu Jul 25, 2013 12:32 am
I was thinking of converting my rear drums to discs on my e10 corolla.. anyone done it? is it a big job?
everyone say it handy done would e11 disc fit?
im in no mad panic to do it yet
ASG14
PostSubject: Re: corolla rear disc brake coversion    Thu Jul 25, 2013 1:54 am
Need rear knuckles with all the brake components as well as parking brake cables. Should all be an easy bolt on. Smile
MCV10
PostSubject: Re: corolla rear disc brake coversion    Thu Jul 25, 2013 5:32 am
Correct, many done it here already. They used system from E11.
After conversion each wheel will be positioned 10mm more to the inside. Keep that in mind...
Hyaku ichi !!
If they don´t have a AE101 in heaven... I´M NOT GOING!!
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Fri Jul 26, 2013 6:08 am
ok thanks
PostSubject: Re: corolla rear disc brake coversion    Fri Jul 26, 2013 8:51 am
Yer its an easy as straight swap
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Sat Jul 27, 2013 11:14 am
do I need another master cyclinder?
this all I need
ASG14
PostSubject: Re: corolla rear disc brake coversion    Sat Jul 27, 2013 2:06 pm
Hard brake lines and Master do not need to be changed. BUT the Proportioning Valve should be changed to even out the pressure better.
MCV10
PostSubject: Re: corolla rear disc brake coversion    Sat Jul 27, 2013 5:29 pm
A few points worth mentioning:
* The brake line no longer gets secured to the rear struts like the drum brake set-up, so make sure the brake line is still attached to the rear calipers when you buy them. This is how it's designed from factory on the disc brake set-up.
* The proportioning valve doesn't need to be changed, but if you have the opportunity to do it then it's advised.
* The long bolt going through the knuckle is usually very difficult to get out as they seize over the years. Soak it with WD-40 and whack the threaded end with a brass hammer (a normal steel hammer will damage the threads completely).
* You don't need the lateral arms for the swap, but they do feature better bushings (rose joints) compared to the factory rubber Corolla ones.
* If you run two toe adjustment arms (the threaded arm towards the back of the car) you can have the ability to adjust the rear camber.
* Make sure the handbrake is released before doing the swap.
Want JDM parts? Hit me up!
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 07, 2013 4:30 am
thanks Very Happy  do I need 2 change shocks?? I got price for the hole rear set up of a 97 BZR levin in 1 lump 120euro it that a good price??
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 07, 2013 4:23 pm
No you can use your original shocks Smile. €120 isn't a bad price for the whole set. See if you can get the proportioning valve thrown in (mounted to the firewall) Approve!
PostSubject: Re: corolla rear disc brake coversion    Thu Aug 08, 2013 5:56 am
Yeah the picture shows all you need. And 120 is dirt cheap! Buy it now! Smile
Also, as mentioned before, it's quite straight forward. If you need help just ask, there's always someone with an answer.
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Thu Aug 08, 2013 9:39 am
proportioning valve is that the master cylinder????
PostSubject: Re: corolla rear disc brake coversion    Thu Aug 08, 2013 5:08 pm
No the proportioning valve is mounted on the left side of the firewall, quite low down. It has 4 brake lines going into it.
PostSubject: Re: corolla rear disc brake coversion    Thu Aug 08, 2013 8:30 pm
The proportioning valve is advised to get the max out of the disks... however it is not mandatory for the swap. I didn't change the valve... still going strong... I do want to change it some day tho, to improve the braking even more, but it has low priority as I need to get the air out again.
But if you (can) do it while changing the brakes... do it rightaway Wink
PostSubject: Re: corolla rear disc brake coversion    Thu Aug 08, 2013 8:51 pm
I agree. I've been running my original proportioning valve for 4-months since the swap and my car brakes fine, but I'm doing more work on the braking system soon so am going to swap over the valve while all the fluid is drained. So if you have the opportunity to do it at the same time then it's definitely worth it Smile
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Thu Aug 08, 2013 9:19 pm
I look at the Levin to see it if on it I rang ya man and he said if it on it I can have it for free
Anyone got any pic of proportioning valve  and where it located so I no what look for????
dose bzr levins have ABS??? my corolla doesn't
is this the proportioning valve?? I was down in scrap yard 2day looking for it
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Tue Aug 13, 2013 5:39 am
do I need pipes for valve??
can I use my control arms?? instead of BZR Levin arms??
ae101_jp
PostSubject: Re: corolla rear disc brake coversion    Tue Aug 13, 2013 7:10 am
Yes that's the proportioning valve...
PostSubject: Re: corolla rear disc brake coversion    Tue Aug 13, 2013 11:17 am
Yes BZ-R Levin's have ABS, but it's perfectly fine to use the proportioning valve on your non-ABS Corolla. That is indeed the proportioning valve you took a photo of. I've never seen one that rusty though....
You don't need any additional pipes for the valve and you can use your current lateral arms instead of the Levin ones.
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Tue Aug 13, 2013 11:00 pm
I be sand blasting the rear axle and spraying it it a lot more rust then valve..
ok thanks for the info! Smile
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 28, 2013 2:33 am
Do I need this was connected to the valve?
I no its clutch cylinder I dnt no why tommy tell me I need it
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 28, 2013 6:08 am
Na you don't need that. That's the clutch release cylinder which bolts to the gearbox. The lines for it are bolted to the front of the proportioning valve, which is probably why it was included, but it's completely unrelated for what you're doing Smile
Dirty1
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 28, 2013 6:34 am
You have never seen to many cars from Ireland or the UK .
Nice easy swap to do once the long bolt comes out easy .
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 28, 2013 6:38 am
I believe Canadian cars suffer more from rust too...
emmet.harten3
PostSubject: Re: corolla rear disc brake coversion    Wed Aug 28, 2013 11:16 pm
my mate tell me I need it... I told him no cause I not doing clutch just rear disc conversion
I think it fact it not same model of car putting every1 off
Page 1 of 3Go to page : 1, 2, 3  Next
