In total there is 1 user online :: 0 Registered, 0 Hidden and 1 Guest :: 1 Bot
 Front brakes
Mattm
PostSubject: Front brakes   Sun Feb 16, 2014 7:29 am
Hey people just wondering if someone could help me out, I've been told that there are two different types of front brake setups for my 95 ae101 sedan could someone please tell me how I work out which ones I need.. Also I'm from Australia if the helps. Any help would be great.. Thanks matt
PostSubject: Re: Front brakes   Sun Feb 16, 2014 10:33 am
All Australian AE101 (1.6L) front brakes should be the same regardless of year, the AE102 (1.8L) ones are slightly bigger however which is possibly where the confusion is coming from
Are you after rotors, pads or calipers?
Mattm
PostSubject: Re: Front brakes   Sun Feb 16, 2014 11:38 am
Thanks a lot I'm after rotors and pads
PostSubject: Re: Front brakes   Mon Feb 17, 2014 3:19 pm
I believe the AU have 255mm rotors along with the JDM sedan's (except the GT) 3 & 5 dr hatchs G & L-Touring wagons.(Same Caliper)
257mm came on the GT-Apex levin FX-GT hatch and BZ-Touring (same caliper)
275mm came on the super Strut versions.
I could be wrong on this and thinking about the FX-GT had 255mm rotors to.
PostSubject: Re: Front brakes   Mon Feb 17, 2014 3:47 pm
According to DBA (who are an Aus company), Australian AE101 sedans/hatches have 238mm front discs, whereas the AE102s have 255mm.
I'll double-check my Gregorys when I get home, fairly sure it's got the differences between the two listed as well (there are slight differences between the calipers too)
Mattm
PostSubject: Re: Front brakes   Mon Feb 17, 2014 7:28 pm
Thanks guys for your help
PostSubject: Re: Front brakes   Tue Feb 18, 2014 11:04 am
I did say I could be wrong  Razz
I'm digging deep into the black hole called a memory
Front brakes
