Sun Sep 24, 2017 7:07 pm by matty gt
In total there is 1 user online :: 0 Registered, 0 Hidden and 1 Guest
Our users have posted a total of 42352 messages in 2925 subjects
 flashing engine light! Q.Q
nemisis
PostSubject: flashing engine light! Q.Q   Thu Nov 20, 2014 7:44 am
Guys I let a guy change my main engine seal the other day, but now when I turn on the ignition the engine light flashes quickly. Any thoughts?? Idk what he did but the car drives like cap now.
PostSubject: Re: flashing engine light! Q.Q   Thu Nov 20, 2014 7:53 am
check the diagnostic port, if 2 of the ports are joined then it will flash quickly ...
try disconnecting the battery and connecting it back again, see what happens..
nemisis
PostSubject: Re: flashing engine light! Q.Q   Fri Nov 21, 2014 2:02 am
Didnt check the diagnostic port, but we did disconnect the battery several times, even left it disconneted for about 30 mins, Still it flashes. But it stops some times, as in some times when i turn on the ignition, no flashing then other times it flashes :\
PostSubject: Re: flashing engine light! Q.Q   Fri Nov 21, 2014 3:47 am
hmmm that is interesting
maybe he messed about with some wired when he took your engine bay apart, try to retrace all the wires leading away from the diagnostic port and make sure they are not trapped or unsheathed or anything
nemisis
PostSubject: Re: flashing engine light! Q.Q   Fri Nov 28, 2014 8:23 am
I got a diagnostic test done and I got codes 21 and 24...can you tell me what these codes are? My engine is the standard 4age 20valve silvertop. Let me know soon as you can
PostSubject: Re: flashing engine light! Q.Q   Fri Nov 28, 2014 9:03 am
code 21 = oxygen sensor error
code 24 = Intake Air Temperature Sensor signal
nemisis
PostSubject: Re: flashing engine light! Q.Q   Thu Jan 08, 2015 9:36 pm
THanks!
