Sun Sep 24, 2017 7:07 pm by matty gt
Our users have posted a total of 42352 messages in 2925 subjects
 Best aftermarket ecu piggy back ?
nemisis
PostSubject: Best aftermarket ecu piggy back ?   Thu Feb 26, 2015 10:45 am
Guys for the 4age 20valve...With black top.computer, what's the best piggy back management you recommend?
PostSubject: Re: Best aftermarket ecu piggy back ?   Tue Mar 03, 2015 2:09 pm
Not aware of a piggyback ecu for our engines unfortunately. Only option would be to go full standalone. I've considered this route for mine, and did a good bit of research in that area. Megasquirt can be the most economical if you get the DIY kits, but it's a lot of work, a lot of wiring, and right now, not enough upgrades on my motor to justify going thru all the trouble.
PostSubject: Re: Best aftermarket ecu piggy back ?   Wed Mar 04, 2015 11:19 am
yea ive been doing some research on this lately too. since im staying auto though im unusre of what standalone to actually get. i emailed megasquirt and they told me their PNP diy ms2 kit would work but to control the engine only. I was hoping i could use the standalone to help adjust the timing for the auto if at all. Im unsure if this is possible but they told me i would have to do a parallel intillation where the stock ecu remains in place to control the transmisison and the ms2 controls the engine.
trufauru
PostSubject: Re: Best aftermarket ecu piggy back ?   Thu Mar 05, 2015 1:23 am
I'm working on adapting the MS-I board 3.0 to the 4AFE and I think I'm almost there, just hadnt have the time/patience to do it
on the video you can see the megasquirt conected with a patch cable to the original wiring, the 14point7 lamda controller, and the notebook, when I turn the ignition to ON, the megasquirt starts just fine and shows the air temp, coolant temp and TPS correctly, the dashboard also lights up correctly, and when I try to start it I get the correct reading from the sensor on the distributor (just like the original ECM works) and see the engine turning, you can also see the Megasquirt modifing the injector pulse width but I had the ignition cable disconected because I didnt wanted to wreck anything.
If I remembler correctlly there is much more information for the 4AGE with megasquirt, but as they said there is nothing you can do if you also need to control the transmision
http://www.powerzone.com.uy
PostSubject: Re: Best aftermarket ecu piggy back ?   Thu Mar 05, 2015 6:46 am
trufauru im not sure if i need to control the transmission per se, i was just checking if i can just use the ms ecu without doing anything extra to control the transmission. if it works as it should then i would be ok
nemisis
PostSubject: Re: Best aftermarket ecu piggy back ?   Mon Sep 28, 2015 9:25 pm
Any one ever tried greddy management ? I was wondering if a greddy ultimate would work
