 2ZZ-GE 7 Speed LSD Corolla build
shah.saib.7
PostSubject: 2ZZ-GE 7 Speed LSD Corolla build   Fri Mar 17, 2017 5:04 am
And at long last started the build.
The Engine is a 2ZZ-GE 1.8L Toyota engine from an 05 Celica with a 6 forward LSD gearbox.
Started the build Tuesday 28 Feb 2017
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Fri Mar 17, 2017 5:37 am
Getting Ready for the swap
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Fri Mar 17, 2017 6:13 am
Bonnet and Intake off
Lifting up the Trusty Old 20 year old engine. It served me very well.
Looks as if the car is bleeding after I took its heart out haha
https://i58.servimg.com/u/f58/19/10/08/54/20170318.jpg" border="0" alt="" />
Setting up the new Engine
Almost ready to go in!
Just realized the exhaust was on the other side of the engine! Mad Now fixing that
She went down well
Widening and Re-Threading the Engine foundation
AND THE 192BHP beast goes in !
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Fri Mar 17, 2017 6:16 am
Wiring and First Start coming soon!
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Sat Mar 18, 2017 7:50 am
Wow that's awesome work bro
sonur
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Sat Mar 18, 2017 3:08 pm
Nice work..
It's amazing how these ae10 model corollas are everywhere in the world Laughing
- Just another corolla -
Cars: Super 7 build - AE86 Twincam Turbo stuff in a frame what could go wrong?
        ML500 4WD Mercedes 2002 33" tires
Bikes: Honda CBR 600 Cafe Racer 1989´
         Honda CBR 600 Cafe Racer 1988´
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Tue Mar 21, 2017 5:51 am
sonur wrote:
Nice work..
these cars are very famous!
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Tue Mar 21, 2017 5:55 am
First start, without the exhaust and incomplete wiring and intake filter
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Tue Mar 21, 2017 6:12 am
How does it sound btw? Feels too loud to me
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Tue Mar 21, 2017 6:15 am
Connected the exaust
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Tue Mar 21, 2017 6:17 am
Thanks, Im trying!
Joeythelips89
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Wed Mar 22, 2017 8:02 am
Nice swap man, was there much involved, did you get your speedo working?
boosted.rolla
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Wed Mar 22, 2017 9:38 pm
wow we have the same car and same engine swap including the original engine though I went to 4e turbo first then now on this 2zz.
The sound is normal, it's the same sound I've experienced when I got no exhaust for 1 month
by the way did you ever got your a/c amplifier working?
the speedometer should work as it is since it still has a sensor on the transmission.
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Thu Mar 23, 2017 3:59 am
on a scale of 1-10, 10 being a lot of work, this was a 7.
setting up the engine mounts was easier than expected and setting up the exhaust lines and setting up the stock gear wires from my 5 speed gear lever to work with a 7 speed, there wasn't much too complicated.
and about the speedo, yeah just plugged in the old wire to the tranny and it fits!. the speedo might be off 5-10 kmh because the speed sensor from the celica transmission was designed for slightly bigger diameter tires than the AE101 standard tires.
just have to set up the RPM to correct resistance from the speedo and it should be great
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Thu Mar 23, 2017 4:09 am
I had thought of going turbo but i think as a daily driver a turbo isnt just that reliable and practical enough so went with NA 2ZZ as it has decent power and torque and no turbo lag haha.
and i admire your patience of running with that sound for a month with no exhaust! When i first heard the engine like this i left everything to work on the exhaust first so testing the engine would be less agony Very Happy
And sorry man I havent yet started working on the AC because my compressor that was with the engine is bad, tried two other compressors but no luck, so haven't really started working on the AC. I will be sure to update this thread once i find a good compressor and start the AC. shouldn't be much work tho
boosted.rolla
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Thu Mar 23, 2017 2:13 pm
yeah man all my neighbors are giving me the stare every time I start the car. great will be waiting for your update, I'm not sure if the tach voltage I'm sending to the a/c amplifier is too low for it to engage automatically for now just used a manual thermostat.
what axle did you use here?
shah.saib.7
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Fri Mar 24, 2017 3:45 am
Using a manual thermostat isn't a bad idea you know, just keep it in the middle and it will be good bothh for thhe compressor and the engine, and as for the amplifier, Did you try to get the AC amplifier from the celica or the xrs (the car from which the engine came from) ? Because most likely the stock ae101 ac amp might not be fully compatible with all this. I may be wrong but its worth a shot.
And I used my stock axles, was about to get the new one but before that just shortened my old axles and re threaded them. They're holding up well up till now tho
haroon.virk
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Sat Mar 25, 2017 9:29 pm
What a wonderful engine and setup.
From where you got this engine and for how much?
haroon.virk
PostSubject: Re: 2ZZ-GE 7 Speed LSD Corolla build   Sat Mar 25, 2017 9:43 pm
Celica 2005 never came with 192 hp. The most powerful version of these engines came in JDM fielder 2003-2004 model, all later models have less hp than 192.
