Go to page : Previous  1, 2, 3, 4 ... 20 ... 37  Next
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Sun Feb 19, 2012 1:26 am
oh dude you better get the under side of car painted its rusting badly.or else you would holes in your chasis.it has happened to my car also also.
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Sun Feb 19, 2012 1:27 am
better to underseal it
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Sun Feb 19, 2012 1:56 am
The sad part is, it has been undercoated with rustcheck (I know because my mechanic was complaining about getting it in his hair lol).
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Sun Feb 19, 2012 2:19 am
Lol
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Sun Feb 19, 2012 2:38 am
Needs to come up at least a 1/2" somehow
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Wed Feb 22, 2012 10:29 am
SONAR Taillights
I ended up taking my car to Sound Concepts to have the trunk panel installed and wired in. I decided to wire the LED lighting up for running lights.
and here is a progressive view of my taillights from stock to aftermarket in the dark...
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Wed Feb 22, 2012 11:45 am
JDM Headlights + Corner Lamps
Now I just need an HID conversion kit. I tried installing them with my stock bulbs but I couldn't get the plug to connect because theirs not enough space to get the plug on. The bulb connection sits flush against that plastic circle.
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Wed Feb 22, 2012 12:35 pm
they look nice, are your original bulbs h4? if so they wont fit in these, you need the 9005/9006 bulb iirc
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Wed Feb 22, 2012 12:43 pm
Heres the bulbs I tried. I have been using them in my stock headlights but dont think there meant for the projector headlights?
Sylvania 9006 Coolblue & 9005 Silverstar
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Wed Feb 22, 2012 1:01 pm
(I had to go and look up what H4 bulbs were lol) No, my original bulbs were 9005 & 9006 then I swapped them for the Sylvania bulbs (same shape as original bulbs).
These bulbs fit in my projector lights, but there is a plastic circle with 3 screws that locks the bulb and it is in the way of me connecting the plug into the wiring harness
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Thu Feb 23, 2012 12:49 am
ah i see what you mean, i have no idea what would, hopefully someone can help..
mirroreyes has the same lights, he may know what bulbs to use
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Thu Feb 23, 2012 4:11 pm
I finally figured out what I needed! I purchased a set of 9005xs & 9006xs Silverstar (cheap ones) bulbs today, but then I noticed that the o-ring seal for the bulbs were too small/narrow to make a proper seal in the headlight socket. So after searching around, I finally found what looked like the proper size o-ring.
Then, to further insure I would have no issues; I brought with me 1 of the tiny stripped screws which go with the plastic lock that seals the bulb in the socket. I ended up finding a pack of screws which were just a fraction bigger, which was perfect because a couple of the holes for the screws were widened out and stripped. Plus there were some scratches on the plastic lock.
Inserting bigger screws in the plastic lock
Seating the rubber O-ring into the socket
Inserting the bulb
Then I went and poked my cars eyes out
And every thing was looking good
Until I put my grill on affraid
Lol, clearly some adjustments need be made!!! Suspect
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Feb 24, 2012 12:01 pm
Night Time Headlight Profile
Stock
Low-Beam
High-Beam
Aftermarket
Low-Beam
High-Beam
Low-Beam (Interior View)
High-Beam (Interior View)
The aftermarket headlights do not light up the road very well! They need major adjustments (well, the low beams anyway). But they look nice
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Feb 24, 2012 3:37 pm
The lighting is pretty terrible in these ones haha. I had some circular ones, like so http://www.ebay.ca/itm/COROLLA-JDM-BLACK-CLEAR-HEAD-LIGHTS-CORNER-LAMP-LEN-4PC-/360431275458?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1993|Model%3ACorolla&hash=item53eb60cdc2 before I had a little accident, they were the brightest of the stock, these square aftermarket ones and themselves.
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Thu Mar 01, 2012 6:05 am
Im starting to get use to the lighting of these headlights, and they seem to be fairly well sealed. Havnt noticed any water vapor inside them yet, except for the corner lenses and the corners of the taillights.
New TRD Radiator Cap Cover and Oil Cap
I should of cleaned up my engine bay for these pics. I also really need to clean or paint my valve cover now to go with that new oil cap lol
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Thu Mar 01, 2012 6:09 am
I cant seem to find the AE101 sticker thread to post my pics. I finally put my stickers on today. I took some pics but its hard to see because of the reflection
Im going to try for some more pics later tonight, should get a better picture then. Im quite happy with the colour of the stickers, its almost a direct match. Though I wish I positioned the one on the windshield a bit lower
...Its now snowing out and my car is currently getting covered so went out to take as many pics as I could to try and get a good pic of the stickers
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Thu Mar 01, 2012 7:00 am
Nice one mate.. Little touches always help bay look nice
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Thu Mar 01, 2012 2:59 pm
Stickers look nice man Very Happy
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 2:59 am
Thanks, Im glad I got them on when I did. We got a horrible snow/ice storm last night (actually, its still snowing as I type). There is about a foot of snow on the ground and my car, plus a thin sheet of ice under the snow which made it difficult to shovel out the driveway. I guess winters not over yet
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 3:05 am
wow... still snowing there santa
its such a beautiful sunny day here in the uk Razz
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 3:26 am
I just shovelled my driveway and brushed the snow off my car about 2 hours ago. and here is how it looks now
Then later on today its suppose to warm up and turn to rain, and rain for the next day or so.
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 4:03 am
Lol that it alot of snow
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 10:26 am
You live down south? (Near Toronto area I mean) haha.
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 10:51 am
lol down south. Yep, but not as far down as Toronto. I live around the Belleville/Trenton area. Which part of Ontario are you from?
PostSubject: Re: Corolla Sound's 97 DX AE101 On-Going Project   Fri Mar 02, 2012 12:26 pm
I am coming up with a list of paint projects for this spring that I want to do.
1. Paint Grill to match car (Green 6P5)
2. Paint Front Calipers and Rear Drums: I have not thought about which colour to paint them yet, but anything would look better then rust. Any suggestions or ideas?
3. Paint interior rear door locks and handles white to match the front
4. Paint the trim around my taillights to match the colour of the car? (still undecided)
5. Paint Valve Cover or just have it sand blasted and cleaned up?
6. Paint my alternator bracket
7. Replace as many rusty parts as possible lol
Page 3 of 37Go to page : Previous  1, 2, 3, 4 ... 20 ... 37  Next
