 AE101 upgrade
Go to page : 1, 2, 3  Next
PostSubject: AE101 upgrade   Mon May 07, 2012 1:33 pm
after thinking about twin pot upgrades to my fxgt and trying different pads and discs is now time to take the plunge after finding a set off a ae111 Levin for $100 nzd I have started to rebuild the twin pot callipers and as I have a spare fxgt wreck I have decided to rebuild the rear while I am doing the front so it will feel like I have new callipers all-round and paint the all red so they look clean and new Very Happy
here are some photos of the twin pots just after i got them
i will post some more photos as i go on after i have the rebuild kits to start work
PostSubject: Re: AE101 upgrade   Mon May 07, 2012 7:03 pm
Where did you get the rebuild kit and how much may i ask??
PostSubject: Re: AE101 upgrade   Tue May 08, 2012 7:18 am
hi im getting them from
Sterling Clutch & Brake
55 Neilson Street, Onehunga, Auckland
and i think they are about $35 nzd each i hope this helps
QuinnyGT
PostSubject: Re: AE101 upgrade   Tue May 08, 2012 2:15 pm
You need to modify the twin pot caliper slightly, and also you need 04 shape d4d corolla Discs to get them to work with Corolla Carriers and the Levin brakes Wink a coupple of guys have done the conversion here and its a good upgrade
PostSubject: Re: AE101 upgrade   Tue May 08, 2012 5:19 pm
im using znoelli brakes that are bigger than the standard ones so i think i might just get off lucky on that one but ill have to see
PostSubject: Re: AE101 upgrade   Tue May 08, 2012 9:26 pm
Yer I know the place, I've had znoelli rotors and wasn't impressed, their actually sitting next to my garage. I know of a guy that can turn down the SS rotors to the right size.
I've also heard that the calipers from the ST185 GT4 bolt straight on using the GT APEX/BZ rotors no messing around with.
By the way your names not Tom is it?
PostSubject: Re: AE101 upgrade   Wed May 09, 2012 9:45 am
yep it is
PostSubject: Re: AE101 upgrade   Wed May 09, 2012 2:14 pm
just got the rebuild kits
[img][/img]
twin pot ae111 rebuild kits
[img][/img]
fx gt rear rebuild kits
[img][/img]
now to get the black and red paint and to start on the mods
PostSubject: Re: AE101 upgrade   Wed May 09, 2012 7:09 pm
Hey how you doing, I bought the hatch trim off you a while back
PostSubject: Re: AE101 upgrade   Thu May 10, 2012 9:13 am
it a small world
PostSubject: Re: AE101 upgrade   Thu May 10, 2012 10:39 pm
It is.
We're having a nz meet Sat 19th if your keen
PostSubject: Re: AE101 upgrade   Fri May 11, 2012 8:51 am
what time as im working on the car so ill have to see if i can
PostSubject: Re: AE101 upgrade   Fri May 11, 2012 5:57 pm
Yet to be decided, I'm thinking meet around 3pm
PostSubject: Re: AE101 upgrade   Thu May 24, 2012 3:44 pm
Brakes are just about ready but are on hold as I need to move work shops to a bigger one
so I have started to look at the cooling system and as mot of you know in NZ its coming up to wof time and my head lights are faded in side and out so I found a full set of bz touring head lights for $300 nzd all look new apart from the lh one but it sill looks better than the old ones ill have to take some photos of the old and new head lights so you can see how bad they are and how good the car looks with them on thanks to some help from my friend as fx gt side lights are in the side not the head lights
PostSubject: Re: AE101 upgrade   Thu May 24, 2012 3:51 pm
for the cooling system im putting a trd 1.3 bar rad cap tridon high flow thermostat and all new coolent pipes in red to mach the car as soon as i get the i will take photos before and after plus the parts as i get them
PostSubject: Re: AE101 upgrade   Mon May 28, 2012 5:32 pm
new tridon thermostat
PostSubject: Re: AE101 upgrade   Mon May 28, 2012 5:42 pm
got this greddy oil catch tanks for $50 NZD so i thought id put it on the car as well
PostSubject: Re: AE101 upgrade   Tue May 29, 2012 12:49 am
nice
PostSubject: Re: AE101 upgrade   Tue May 29, 2012 2:39 am
Nice additions!
PostSubject: Re: AE101 upgrade   Tue May 29, 2012 5:35 pm
just got the new coolant pipes just waiting on the trd radiator cap and then i can start work on the car. I'm going to try and do the brakes and the coolant upgrades at the same time then i can start on the intake system when i find a k&n filter.
pic of the coolant pipes before i put them in the box with all the outer parts
done any one know where i can get clear indicator lights for a fx gt bumper as its the last piece to my front lights upgrade but im finding it hard to find them in nz
PostSubject: Re: AE101 upgrade   Fri Jun 08, 2012 10:28 am
just went for a nz wof of in the uk its called a mot i think it been 8 years since i lived in the uk so if im wrong sorry but the car failed on the rear sway bar bush and sway bar (crap) No
i found out that the rear sway bar is bent so time to get a new one Very Happy .
i found that white line do a 18mm sway bar for $200 nzd
new tie rods
time to have some fun with new parts this weekend
PostSubject: Re: AE101 upgrade   Fri Jun 08, 2012 10:34 am
nice, and yes its called an MOT
PostSubject: Re: AE101 upgrade   Fri Jun 08, 2012 11:33 am
thanks it sounds like not much has changed
PostSubject: Re: AE101 upgrade   Fri Jun 08, 2012 11:51 am
haha not really
PostSubject: Re: AE101 upgrade   Mon Jun 11, 2012 1:01 pm
ok after a long week end of work on the car swapped all the coolant hoses and fitted the new sway bar and the new catch tank not the g reddy one as their is no room in the engine bay to fit it DAM IT . So I pulled the one of my mr2 that’s still new and fitted it. Let’s just start with wow the car gets a bit hotter and what a change it pulls a lot better and at lower rpm and the sway bar is so much better just need to work on the brakes now. I will post pics soon
And I will have pics for the whole car as soon as it gets its tints on Twisted Evil
AE101 upgrade
Page 1 of 3Go to page : 1, 2, 3  Next
