Our users have posted a total of 42378 messages in 2930 subjects
 3S-GE Swap into a corolla!!
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Aug 28, 2012 3:40 am
pilyoto
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Aug 31, 2012 4:14 pm
Shocked
i'd rather be sleeping Sleep
ROLLAenthusiast187
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Oct 12, 2012 12:31 pm
wow thanx so much at least i have an idea now of what i need.... dam! 255 + in a corolla i like Twisted Evil
ROLLAenthusiast187
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Oct 12, 2012 12:40 pm
what kind of transmission would i need with a 3sge swap?? Shocked
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Oct 12, 2012 9:27 pm
i used the stock s54 box
ROLLAenthusiast187
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Oct 13, 2012 5:59 am
so if the 3sgte transmission is part of the sale im good to go then right? cause i have an automatic and im guessing im gonna need to make a whole on the firewall to put the clutch right?
humidade
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Oct 13, 2012 6:04 am
yep
Having a Honda it's like being GAY, it's more acceptable but it's still wrong lol!
JAPSquad xD Member nº: 203
akuma64
PostSubject: Re: 3S-GE Swap into a corolla!!   Sun Nov 11, 2012 7:08 am
im getting closer to beginning a swap in my rolla. however while im most likley going with blacktop...i keep coming back to 3sge. i was thinking redtop but with the price and aftermarket support..id be better off with the 3sge like yours here in the states. now from what ive heard 230 to to 250 iss being produced from this engine stock? correct me if im wrong.....lol well im not looking for a racecar and i just want my car reliable for everyday with a little more umph.....which is why i was going blacktop....but besides fabrication...how reliable is this engine? im still sort of convinced that for the buck and longevity the blacktop is for me.
Enjoy Corolla alien
PostSubject: Re: 3S-GE Swap into a corolla!!   Sun Nov 11, 2012 8:50 am
the rev 3 3sge is bulletproof, never seen any actually blow up or die no matter what mileage.
the 3sge doesnt really have alot of aftermarket support but thats the same with most toyota n/a engines.. breathing mods and aftermarket cams, piggyback ecu.. and you could push it to around 250bhp n/a roughly..
they came 168bhp (with egr) or 175bhp (without egr)
the redtop beams came with 200bhp..
cedric95
PostSubject: what does the rav4 3sge ax10 mount look like?   Thu May 02, 2013 3:20 pm
Engine and box:
93-99 Celica GT 3sge
ECU & Wiring:
93-99 Celica GT 3sge engine loom & ECU & corolla 1.3 corolla gli loom
Engine Mounts to fit Ae101 / E10:
timing belt side engine mount use a Rav4 3sge ax10 mount.
gearbox side use a corolla one and redrill to fit S54 box
Front mount use corolla/celica mount
Rear mount use corolla/celica mount
Driveshafts:
ST182 driver side shaft
MK2 Rev2 MR2 Passenger side shaft
Fuel Pump:
stock or Walbro fuel pump
Brakes:
Avensis calipers
Cooling:
St202 rad
Thats it! No custom work except wiring !!! Very Happy
monkeypower102
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu May 30, 2013 9:17 pm
Just out of curiousity, how do the angle of the driveshafts compare between the 3sge vs stock? Do the axles have any more angle in one direction vs another? It would be awesome to rock such a swap but I really want to know whether or not being slammed will take too much of a toll on the driveshafts
Work in progress
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu May 30, 2013 9:47 pm
I've found a couple of rev 3 3sgte's and now I'm thinking
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri May 31, 2013 2:05 am
Beams 3sge in the sedan?
monkeypower102
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri May 31, 2013 3:33 am
Just a thought haha
Work in progress
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri May 31, 2013 5:23 am
the driveshafts are similar to the stock shafts, the engine sits like its supposed to stock..
im sure iv got afew pics of the underside
cedric95
PostSubject: What's the bottom piece of the rav4 mount from?   Sat Jun 01, 2013 1:54 pm
cedric95 wrote:
Engine and box:
ECU & Wiring:
Driveshafts:
Fuel Pump:
Brakes:
Avensis calipers
Cooling:
St202 rad
jason.french.313
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Oct 04, 2013 8:13 pm
in regards to the below
you get the entire 182 shaft and the entire mr2 shaft and they will work with the ae101 hubs?
in regards to the mks rev2 ? do you mean the sw20? we don't use rev1 etc in Australia Sad
regards
jay
jason.french.313
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Oct 04, 2013 8:59 pm
really want to go get all the parts!
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Oct 04, 2013 9:11 pm
yes the sw20
the shafts fit perfectly with the ae101 hubs
jason.french.313
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Oct 05, 2013 12:43 am
thankyou verymuch
one more question i may have missed reading through all of your posts was the shifter cables?
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Oct 05, 2013 11:19 am
used celica shifter cables
jason.french.313
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Oct 05, 2013 9:15 pm
i just found a celica in my local scrap yard Smile
all there as well.
would it be a good idea to take the entire shift mechanism off the floor and transfer the whole lot onto the ae floor?
PostSubject: Re: 3S-GE Swap into a corolla!!   Sun Oct 06, 2013 11:24 am
no, just need the shifter cables, i used the stock corolla shifter
jason.french.313
PostSubject: Re: 3S-GE Swap into a corolla!!   Sun Oct 06, 2013 7:50 pm
great im of to the scrap yard next weekend
thankyou
Currymeister
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Nov 19, 2013 8:43 am
Hi just a quick re:
Driveshafts:
Do you mean the whole driveshaft unit which includes the cvs? Will they join the ae101 hub?
Cheers mate
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
