 3S-GE Swap into a corolla!!
Go to page : Previous  1, 2, 3, 4
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Nov 19, 2013 8:45 am
those shafts fit into a corolla hub, same spline count
PKK
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu Jan 30, 2014 9:51 am
Engine Mounts to fit Ae101 / E10:
timing belt side engine mount use a Rav4 3sge ax10 mount.
gearbox side use a corolla one and redrill to fit S54 box
Front mount use corolla/celica mount
Rear mount use corolla/celica mount
 Very Happy
Savage build man fair play im hoping to do the same myself.
in relation to the mounts when you say corolla/celica mount does that mean they are the same mount.
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu Jan 30, 2014 11:48 am
thanks man,
no its a mix of corolla and celica mount.. cradle from one and mount from the other... i cant remember 100% which is which sorry
Currymeister
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Jan 31, 2014 3:47 pm
Can you let us know when you remember bro
Currymeister
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Jan 31, 2014 3:50 pm
Another thing I need to buy for my swap lol
Although I am getting an st202 front cut so I can try and get it right
PKK
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Feb 01, 2014 7:23 am
Cheers just found ur build thread half way thru savage read
PostSubject: Re: 3S-GE Swap into a corolla!!   Sat Feb 01, 2014 10:41 am
thanks mate
demogorgon15
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Jul 22, 2014 6:06 am
was the St202 radiator necessary or did you just do it as an upgrade?
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Jul 22, 2014 11:14 am
it was for me going from a 4e rad, the hose placement are in a different location
demogorgon15
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Aug 01, 2014 8:51 am
Just got a call from my mech saying basically the same thing, would you or anyone else happen to know what other vehicles may have come with a radiator with a similar hose orientation? it might be hard to find a st-202 rad in my country. would a rad from a 3s altezza work?
PostSubject: Re: 3S-GE Swap into a corolla!!   Wed Jan 21, 2015 11:58 am
this is amazing i always found it interesting and ive always wanted to go turbo but it just seemed to complicted for me. however, one of my best friends just told me of a good friend of his who just opened up a shop about 5 min from me that specializes in mr2 gen 4 swaps!!!!!! i asked them about doing the swap into my corolla and they said due to needing custom mounts and a slew of other items that it wouldnt be cost effective for them to do Crying or Very sad They quote a basic gen 4 3sgte swap into a rav4 at around $7500!!! seems like a lot but they do legit work and it pretty much would be like it were stock. Do you think they were right? If i got these parts (axles, mounts, etc.) could i sway their minds. Also $7500 would be motor, trans, ecu, wiring etc needed to complete the basic swap
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu Jan 22, 2015 10:02 am
i think you could..
you could show them my build thread if you want.. see what they say.
7500 seems like a lot of money though, no?
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu Jan 22, 2015 12:00 pm
it is a lot lol. i was just curious
Currymeister
PostSubject: Re: 3S-GE Swap into a corolla!!   Sun Jun 21, 2015 3:54 pm
Engine and box:
93-99 Celica GT 3sge
ECU & Wiring:
93-99 Celica GT 3sge engine loom & ECU & corolla 1.3 corolla gli loom
Driveshafts:
ST182 driver side shaft
MK2 Rev2 MR2 Passenger side shaft
Fuel Pump:
stock or Walbro fuel pump
Brakes:
Avensis calipers
Cooling:
St202 rad
Thats it! No custom work except wiring !!!  Very Happy
Sorry to bother you so late
What shifter cables do you recommend ?i noticed you cut and welded the celica ones you installed
K1ngL30
PostSubject: Re: 3S-GE Swap into a corolla!!   Thu Jun 25, 2015 10:55 am
I'm planning on doing this to my rolla but I have a 5sfe and a transmission off a Mr2 2nd gen. My corolla is auto at the moment. I know the tranny is going to need some custom work, but I wanted to know if this swap can be done using a 5s. Also if you have any suggestions please let me know.
PostSubject: Re: 3S-GE Swap into a corolla!!   Fri Jun 26, 2015 10:45 am
Hi,
I can't see it not working with a 5S, As far as i know there was a member on the club who had a 5S build.
Which box is it from the MR2?
S54 or E153
K1ngL30
PostSubject: Re: 3S-GE Swap into a corolla!!   Mon Jun 29, 2015 2:55 am
I'm pretty sure it's the s54. And also I'm planning on putting a 3sgte head on the 5s block. I wanted to ask if it were possible to just throw the head on there n/a without having to change piston heads?
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Jun 30, 2015 4:51 am
i dont know if it all fits together perfectly
Joeythelips89
PostSubject: Re: 3S-GE Swap into a corolla!!   Tue Sep 22, 2015 10:26 am
did you do the wiring on this yourself?
My Toyota trueno bz-r 20v
http://www.ae101ownersclub.com/t1649-ae111-toyota-trueno-bz-r-20v#29298
Parts for sale
http://www.ae101ownersclub.com/t1648-ireland-parts-clearout#29290
Page 4 of 4Go to page : Previous  1, 2, 3, 4
