20v tailights probelm EmptyMon Aug 21, 2023 2:26 am by motorsportbd
20v tailights probelm EmptyMon May 15, 2023 6:13 am by emmet.harten3
20v tailights probelm EmptyMon May 15, 2023 5:32 am by emmet.harten3
20v tailights probelm EmptyMon May 15, 2023 5:30 am by emmet.harten3
20v tailights probelm EmptyMon May 15, 2023 5:29 am by emmet.harten3
20v tailights probelm EmptySat Feb 11, 2023 2:08 am by emmet.harten3
20v tailights probelm EmptySat Feb 11, 2023 1:30 am by emmet.harten3
20v tailights probelm EmptySun Feb 05, 2023 1:53 pm by gold94corolla
20v tailights probelm EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
20v tailights probelm EmptyThu Dec 29, 2022 7:47 am by prnguy
20v tailights probelm EmptySun Sep 04, 2022 1:44 pm by kaitaiya
20v tailights probelm EmptySat Sep 03, 2022 12:36 pm by gold94corolla
20v tailights probelm EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
20v tailights probelm EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
20v tailights probelm EmptySat Jun 25, 2022 11:23 pm by Batezy11
In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 2 Bots
20v tailights probelm I_vote_lcap20v tailights probelm I_voting_bar20v tailights probelm I_vote_rcap
5 posters
emmet.harten3
emmet.harten3
PostSubject: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 6:06 am
hi i fitted 20v tailights on my xli corolla and the brake light is on when i turn on my lights on driver side and when i put my foot on brakes nothing happens it stays on?? the passenger side is working fine any ideas??
reason why i ask is cause it too dark to check it out so i look 2morow
20v tailights probelm Dsc01022
brake lights turn on the driver side
20v tailights probelm Dsc01024
foot on brakes and working normal. but driver side stay on when you take your foot off
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 6:16 am
Maybe it's just the bulb... could be that the bulb only has one (single fillament) "wire" instead of two (dual fillament). Otherwise there could be something wrong with the wiring, maybe someone soldered two wires together?
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 6:19 am
My first thought is the bulb to, then possibly the wiring
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 6:42 am
the bulb warning is turned on by the negative side try bringing the negative from the battery and see if the warning turns off . as far as i can tell the fx lights are the same as the other hatchbacks
emmet.harten3
emmet.harten3
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 6:45 am
it all plug and play i plug it 20v harness with xli loom and it on now
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 7:03 am
check the bulb, check the fog light switch, check the wiring behind the lights..
emmet.harten3
emmet.harten3
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 9:11 am
it not fog. check already i check bulbs 2morow
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 9:14 am
it should be a dual filament bulb
emmet.harten3
emmet.harten3
PostSubject: Re: 20v tailights probelm   20v tailights probelm EmptyWed Feb 27, 2013 9:25 am
i see what is... have to get new bulbs anyways cause of new laws in lreland
» 3 Door Tailights
