| Internet problems!! :grr: | |
Yankee Norway Rep
Posts : 645 Reputation : 5 Join date : 2013-01-17 Age : 40 Location : Norway
 | Subject: Internet problems!! :grr: Tue Mar 19, 2013 7:49 am | |
| Goddamn internet box!!
Always quiting when I least expect you to you m***********gPOS!! !"#¤%&/ (CENCORED) !"#¤%&/ !"#¤%"#¤% !"#¤%& I'VE ALMOST HAD IT!!!!! Get bent you useless piece of plastic!! | |
MirrorEyes Canada Rep
Posts : 1540 Reputation : 43 Join date : 2011-09-26 Age : 29 Location : Ontario, Canada
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 10:05 am | |
| Hahaha I know that feel bro. Technology, right? | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 10:11 am | |
| Yeah, technology sucks! (most of the time) | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 11:56 am | |
| It sure does and I've had problems since I got my apartment in march 2010. | |
Ferdinand Member
Posts : 77 Reputation : 1 Join date : 2013-03-14 Age : 39 Location : Cape town, South Africa
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 5:07 pm | |
| LOL the more you get pissed off the more it acts up | |
knite Supreme Member!
Posts : 1102 Reputation : 15 Join date : 2012-07-08 Location : Kent
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 6:36 pm | |
| lol whats wrong with it ? | |
Ferdinand Member
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 6:45 pm | |
| Nothing wrong with mine. just pretending to be sad so that Yankee doesnt feel alone | |
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 8:51 pm | |
| lol fair doos  | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 10:26 pm | |
| My internet box drops out every now and then and has been doing so since I moved into this apartment back in 03.2010 | |
 | Subject: Re: Internet problems!! :grr: Tue Mar 19, 2013 10:52 pm | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Wed Mar 20, 2013 2:28 am | |
Sgt_Lyna Supreme Member!
Posts : 1243 Reputation : 24 Join date : 2011-07-12 Age : 35 Location : Netherlands
 | Subject: Re: Internet problems!! :grr: Wed Mar 20, 2013 9:32 am | |
| Is the box failing, or just the connection from the box to the web? Ergo is the icon on your taskbar a network icon with a red cross or a yellow exclamation mark in a triangle? And most importantly, what kind of box (I presume router) are you using at the moment? | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Wed Mar 20, 2013 9:37 am | |
| I'm not sure what part is failing but when it happens my network icon turns into a triangle with a yellow exclamation mark, also I'm using something called an AirCruiser Ultra N Router and its my second one since I moved in here, in my last apartment I never had any internet problems but that place was a healthrisk! | |
 | Subject: Re: Internet problems!! :grr: Wed Mar 20, 2013 9:05 pm | |
| Ok, that sounds like a LAN to WAN issue... meaning it's not in the cabling from the PC to the router.
Have you check (or replaced) the wiring from the router to your internet access? (the patchport in the wall going outside)
Otherwise it could be a software issue in the router itself. Have not yet had the time to check what kind of router is it exactly. | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Thu Mar 21, 2013 12:10 am | |
| Sgt_Lyna: I've replaced everything, even the laptop! | |
 | Subject: Re: Internet problems!! :grr: Thu Mar 21, 2013 1:23 am | |
| Are you using wifi? And do you have the same problems using a cable? | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Thu Mar 21, 2013 1:28 am | |
| My internet only works when I'm using a cable, my other laptop (I have 3, this big one, a small one I use for editing photos and 1 that is gonna be rebuilt) does not work on wireless either. | |
 | Subject: Re: Internet problems!! :grr: Thu Mar 21, 2013 8:52 am | |
| Ok fair enough, so you have replaced all cabling? Have you tried upgrading the firmware on the router maybe? Or have you upgraded it before you moved in? That could cause problems... | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Thu Mar 21, 2013 9:11 am | |
| It was after I moved in here that the problems started, at one point I actually wanted to move away from this place just because of the internet problems. (I still kinda wanna move away but can't afford it) | |
 | Subject: Re: Internet problems!! :grr: Thu Mar 28, 2013 7:35 am | |
| And you did not change any of the settings? | |
Yankee Norway Rep
 | Subject: Re: Internet problems!! :grr: Thu Mar 28, 2013 7:49 am | |
| Nope, but my internet works perfectly now  | |
 | Subject: Re: Internet problems!! :grr:  | |
