Corollove Elite Member
Posts : 152 Reputation : 3 Join date : 2012-11-21
 | Subject: Wiring a tach? Thu Apr 04, 2013 6:36 am | |
| My friend just installed a tach cluster into his ae101 and everything is plugged in but the tach isn't getting a signal. i presume it isn't prewired for the tach. Could anyone help me out on wiring the tach? Such as which pins control the tach? Thanks | |
kickfli12 Elite Member
Posts : 494 Reputation : 16 Join date : 2011-11-16 Location : Greensboro, North Carolina, USA
 | Subject: Re: Wiring a tach? Thu Apr 04, 2013 8:59 am | |
| Well buddy, take the cluster out and look at the middle plug as if it were plugged into the cluster. 5th pin from the left. f its were wired for one there would have been a blue wire there. You'll need a pin out of a another Speedo plug to put there. Then run that wire through the firewall into the tach signal of the diag box or run it to the black wire on the distributor plug. | |
 | Subject: Re: Wiring a tach? Thu Apr 04, 2013 9:20 am | |
 | Subject: Re: Wiring a tach?  | |
