| How to Jack up an AE101 and place Axle Stands | |
+4magweal Argew24 MirrorEyes Corolla Sound 8 posters |
Corolla Sound Supreme Member!
Posts : 1102 Reputation : 15 Join date : 2012-02-05 Age : 37 Location : Ontario, Canada
 | Subject: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 7:54 am | |
| Can someone with more experience add to this thread. I am wondering if it is safe to jack up my car with a piece of wood under a floor jack which is on wheels? The floor jack will not lift high enough to get the tires off the ground. I have a solid 2x9x25" piece of lumber to use, but im afraid the jack will somehow roll out. I am also wondering if it is safe to place jack stands under the frame rails? Or what I think are the frame rails? (Where the red circle is?)  I used my oem jack to lift from the jack point and the seam/sill folded on me after the tire lifted off the ground. So depressing. So I have no choice now other than to lift it from the front and rear center jack points. Especially since the rear side jack points are rusted ever worse. | |
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 8:40 am | |
| I have found that it is OK to use a piece of wood under the jack. I just tried it and had the tires almost off the ground but backed off after hearing more cracking sounds?  I lifted the car from that jack point (with out the rag). Is this strong enough to take the entire front weight of the car? I dont like how it makes cracking noises as I lift it, but it didn't appear to be damaged after lowering the jack | |
MirrorEyes Canada Rep
Posts : 1540 Reputation : 43 Join date : 2011-09-26 Age : 29 Location : Ontario, Canada
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 4:21 pm | |
| I think I have the same jack as you haha, I got mine at Canadian Tire, and I only really ever used the front and rear jack points as I was scared of my side jack points being too weak from rust. It worked for me so you should have no problem haha. | |
Argew24 Supreme Member!
Posts : 1053 Reputation : 28 Join date : 2012-04-15 Location : New Zealand
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 5:56 pm | |
| Personally I never trust any Jack if I need to work with one safety always first ...jack first then I use building blocks or even better ramps or jack stands. If it drops and races away ... | |
magweal New Zealand Rep
Posts : 1403 Reputation : 42 Join date : 2011-12-14 Age : 40 Location : Auckland, New Zealand
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 9:02 pm | |
| That looks like a good point to jack it up, the creaking sounds should be normal. Where do they sound like there coming from? | |
1993 fxgt Elite Member
Posts : 262 Reputation : 3 Join date : 2012-01-12 Age : 34 Location : auckland
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 9:10 pm | |
| my cars to stiff to make a noise when jacking you the car | |
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Mon Apr 08, 2013 9:16 pm | |
| I'm working on that to lol | |
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Tue Apr 09, 2013 1:07 am | |
| Hey, I got mine at Canatian Tire as well lol, must be same jack lol.
I think the cracking sounds are just the suspension lifting but I cant tell if the front jack support is bending. Im just worried that it will just fold and bust right through into my engine bay, but I think I am being a bit paranoid.
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Tue Apr 09, 2013 2:54 am | |
| Well your jack rail things look much better than mine! But it's using those types of jacks that ruin them. Mine were both completely destroyed on both cars, but I still jack it up there anyway lol. | |
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Tue Apr 09, 2013 5:37 am | |
| i use the stock scissor jack to lift the car up, then put a block / brick under it, then rejack to get it high enough, then leave it big blocks lol | |
John-117 Member
Posts : 116 Reputation : 5 Join date : 2013-02-14 Age : 33 Location : Montreal,Quebec, Canada
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Tue Apr 09, 2013 5:53 am | |
| LOL me too I can't jack like in the first pictures. It's soo rusted that when you jack the metal crisp and disaggregated literaly. Soo i jack in another spot. | |
 | Subject: Re: How to Jack up an AE101 and place Axle Stands Tue Apr 09, 2013 11:19 am | |
| I found that using the front and rear center jack points worked the best for me. The front one is shown in the picture above and this is the rear one I used.  I actually ended up using 2 blocks of wood UNDER the jack to lift the front to get it high enough without raising the floor jack to its max lift range. Another key feature I found was to make sure you lift on level ground. I spent a lot of time positioning the jack on top of the wood and making sure the wood was level. I finally got the block of wood level and raised the car with the jack but when the tires were almost off the ground, I could clearly see that the jack was on 3 wheels because the car was not level (I think). I ended up moving the car over a bit and it was sitting more level. Heres what I mean:    I had the board level and the wheel would spin like that and was not firmly on the ground/board because the car was leaning to one side. The concrete is all chewed up and not perfectly flat and one of my tires was sitting lower. And I never even really used my axle stands, just slid them under the sills just incase:  Im starting to feel more comfortable with lifting a vehicle. I also found some vandalism on my car, looks like a bunch of kids spray painted under neath my car with some kind of rust coloured paint.... | |
 | Subject: Re: How to Jack up an AE101 and place Axle Stands  | |
