mhellinium_bug New Member
Posts : 1 Reputation : 0 Join date : 2013-05-30
 | Subject: digital clock installation Thu May 30, 2013 2:03 am | |
| hello guys! I want to ask how to connect the wiring for the clock. i dont have the plug in my harness. can you help me with this? thanx... | |
Argew24 Supreme Member!
Posts : 1053 Reputation : 28 Join date : 2012-04-15 Location : New Zealand
 | Subject: Re: digital clock installation Sat Jun 01, 2013 5:21 pm | |
Hiro Super Member
Posts : 544 Reputation : 16 Join date : 2012-04-27 Age : 39 Location : Newcastle, Australia
 | Subject: Re: digital clock installation Sun Jun 02, 2013 7:14 pm | |
| If you don't have the plug there for it then just tap into the headunit wiring - from memory you only need ground, constant +12V (for memory) and ignition-switched +12V (unless there is a dimmer wire too)
I had to do this since the Australian models never came fitted with the clocks so there was no point including the plugs in the harness. | |
 | Subject: Re: digital clock installation  | |
