Cold Air Intake EmptyMon Aug 21, 2023 2:26 am by motorsportbd
Cold Air Intake EmptyMon May 15, 2023 6:13 am by emmet.harten3
Cold Air Intake EmptyMon May 15, 2023 5:32 am by emmet.harten3
Cold Air Intake EmptyMon May 15, 2023 5:30 am by emmet.harten3
Cold Air Intake EmptyMon May 15, 2023 5:29 am by emmet.harten3
Cold Air Intake EmptySat Feb 11, 2023 2:08 am by emmet.harten3
Cold Air Intake EmptySat Feb 11, 2023 1:30 am by emmet.harten3
Cold Air Intake EmptySun Feb 05, 2023 1:53 pm by gold94corolla
Cold Air Intake EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
Cold Air Intake EmptyThu Dec 29, 2022 7:47 am by prnguy
Cold Air Intake EmptySun Sep 04, 2022 1:44 pm by kaitaiya
Cold Air Intake EmptySat Sep 03, 2022 12:36 pm by gold94corolla
Cold Air Intake EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
Cold Air Intake EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
Cold Air Intake EmptySat Jun 25, 2022 11:23 pm by Batezy11
In total there are 17 users online :: 0 Registered, 0 Hidden and 17 Guests
Cold Air Intake I_vote_lcapCold Air Intake I_voting_barCold Air Intake I_vote_rcap
 Cold Air Intake
Scott Sillitoe
Scott Sillitoe
PostSubject: Cold Air Intake   Cold Air Intake EmptyThu Jul 09, 2015 5:52 pm
Hi guys,
I was wondering what the best way to fit a cold air intake to a 7afe? I have looked around the engine bay and the only way to make it work is to go around the engine and down next to the headers, which kind of defeats the purpose...
My other option is to relocate everything (battery, engine coolant bottle etc) but I really don't want to do that. Like if it comes to that then I'm probably not going to do it.
Or should I just fit a short ram intake instead? I definitely don't want to keep the factory setup though.
Cheers guys  Very Happy
(P.S. Im in Australia so I need to have some sort of a box around the filter by law. min 3 sides around the box Sad if that makes a difference)
PostSubject: Re: Cold Air Intake   Cold Air Intake EmptyFri Jul 10, 2015 9:09 am
Depending on what state you are in (and how pedantic you are) you can get away with an exposed pod filter as long as it's not in the engine bay itself - mine is mounted between the bumper and the passenger wheel inside the front guard where the old intake resonator used to sit, there's a hole through the guard just behind the battery that the resonator connects to the intake snorkel just before the airbox (obviously the snorkel and airbox have been removed in my case Razz). Angle it right and you only need a single bend in an alloy pipe from the vertially-mounted pod to the existing rubber elbow coming off the throttle body.
Cold Air Intake CAI
Cold Air Intake P1060143
Cold Air Intake P1010042
Cold Air Intake P1060137
Scott Sillitoe
Scott Sillitoe
PostSubject: Re: Cold Air Intake   Cold Air Intake EmptyFri Jul 10, 2015 5:21 pm
Thanks for this. it does help. I'm in NSW by the way. Did you have a sensor going into the factory air box? I think that's what it is. its a black plug with a wire running off it going into the bottom part of the of the factory airbox. What should I do about that?
Also, do you ever get water getting into the filter in that location? and could I also change that rubber hose off the throttle body into one of those blue air hoses (like the ones used for inter cooler piping) Cause I would really like to get rid of that black plastic box (probably a resonator or restrictor) coming off the rubber tube towards the firewall.
Thanks heaps by the way Smile
PostSubject: Re: Cold Air Intake   Cold Air Intake EmptyFri Jul 10, 2015 5:58 pm
The sensor is the intake air temp sensor, my intake pipe has a hole in it with a bung for the sensor to plug in to (you can see it in the third and fourth picture
Never had a problem with water getting sucked into the engine, and I've driven through some pretty big puddles. It is mostly protected by the guard so you basically have to be stationary in a puddle half a metre deep (the filter will only suck in water once it is completely submerged, otherwise it will just pull in air from above the waterline) in which case you've probably screwed the car anyway.
Cold Air Intake
» cold air box question
» Cold weather gear changes
» Intake for AE101
» OEM Exhaust and Intake Sizes and other Specifications
» Custom 4e/5e Intake Manifold and T/B kit
AE101 Owners Club :: AE101 Tech: DIYs, Q&A :: Exhausts & Intakes-
