5AFE ECU HELP!! EmptyMon Aug 21, 2023 2:26 am by motorsportbd
5AFE ECU HELP!! EmptyMon May 15, 2023 6:13 am by emmet.harten3
5AFE ECU HELP!! EmptyMon May 15, 2023 5:32 am by emmet.harten3
5AFE ECU HELP!! EmptyMon May 15, 2023 5:30 am by emmet.harten3
5AFE ECU HELP!! EmptyMon May 15, 2023 5:29 am by emmet.harten3
5AFE ECU HELP!! EmptySat Feb 11, 2023 2:08 am by emmet.harten3
5AFE ECU HELP!! EmptySat Feb 11, 2023 1:30 am by emmet.harten3
5AFE ECU HELP!! EmptySun Feb 05, 2023 1:53 pm by gold94corolla
5AFE ECU HELP!! EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
5AFE ECU HELP!! EmptyThu Dec 29, 2022 7:47 am by prnguy
5AFE ECU HELP!! EmptySun Sep 04, 2022 1:44 pm by kaitaiya
5AFE ECU HELP!! EmptySat Sep 03, 2022 12:36 pm by gold94corolla
5AFE ECU HELP!! EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
5AFE ECU HELP!! EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
5AFE ECU HELP!! EmptySat Jun 25, 2022 11:23 pm by Batezy11
5AFE ECU HELP!! I_vote_lcap5AFE ECU HELP!! I_voting_bar5AFE ECU HELP!! I_vote_rcap
 5AFE ECU HELP!!
Chxxx246
PostSubject: 5AFE ECU HELP!!   5AFE ECU HELP!! EmptyFri Jun 10, 2016 8:12 am
I have a 5afe with a 2 pin(26p, 16p) harness to be connected to the ecu, however the ecu I received is a 4afe ecu with a 26p, 16p, 12p......my question is will this work or will I have to get a new harness or a new ecu to accommodate.
Thanks in advance.
redwing0001
PostSubject: Re: 5AFE ECU HELP!!   5AFE ECU HELP!! EmptySun Jun 19, 2016 3:18 pm
buy a harness adapter.... 26-16 (male from harness) to 26-16-12 (female to ecu connector) so you can use the 4afe ecu on your harness.... You may need to repin the harness adaptor to use the relevant pins there.
You may also need to open the 4afe and the 5afe ecu to find which pins need repinning. All Denso ecus' have a pin name that you can use as a guide.
without an ecu as a guide, trace which wires go where on your harness connector then repin the harness adapter to connect that wire to the correct pin on the 4afe ecu.
Toyoloog
Toyoloog
PostSubject: Re: 5AFE ECU HELP!!   5AFE ECU HELP!! EmptyTue Jul 05, 2016 4:05 am
Even then your ECU will overfuel the engine making it run rich in open loop.
redwing0001
PostSubject: Re: 5AFE ECU HELP!!   5AFE ECU HELP!! EmptyTue Jul 05, 2016 7:30 pm
it may not since 4afe and 5afe usually use the same injectors.... 172 or 176 cc/min grey (or was it beige?) if I am correct, this is the part number of the fuel injector used on both engines: 23250-16160
most factory ecus also have a learn mode where it (I think) it compensates for the fuel injectors, provided the ecu has an oxygen sensor installed there as well.
5AFE ECU HELP!!
» going from 5afe to 4afe
» 5afe into NP 90 starlet
» 5afe engine
» 5afe cutt offs
» 5afe fuel economy
AE101 Owners Club :: AE101 Tech: DIYs, Q&A :: Other Technical-
