calibrating speedo ae 101 EmptyMon Aug 21, 2023 2:26 am by motorsportbd
calibrating speedo ae 101 EmptyMon May 15, 2023 6:13 am by emmet.harten3
calibrating speedo ae 101 EmptyMon May 15, 2023 5:32 am by emmet.harten3
calibrating speedo ae 101 EmptyMon May 15, 2023 5:30 am by emmet.harten3
calibrating speedo ae 101 EmptyMon May 15, 2023 5:29 am by emmet.harten3
calibrating speedo ae 101 EmptySat Feb 11, 2023 2:08 am by emmet.harten3
calibrating speedo ae 101 EmptySat Feb 11, 2023 1:30 am by emmet.harten3
calibrating speedo ae 101 EmptySun Feb 05, 2023 1:53 pm by gold94corolla
calibrating speedo ae 101 EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
calibrating speedo ae 101 EmptyThu Dec 29, 2022 7:47 am by prnguy
calibrating speedo ae 101 EmptySun Sep 04, 2022 1:44 pm by kaitaiya
calibrating speedo ae 101 EmptySat Sep 03, 2022 12:36 pm by gold94corolla
calibrating speedo ae 101 EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
calibrating speedo ae 101 EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
calibrating speedo ae 101 EmptySat Jun 25, 2022 11:23 pm by Batezy11
In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
calibrating speedo ae 101 I_vote_lcapcalibrating speedo ae 101 I_voting_barcalibrating speedo ae 101 I_vote_rcap
Michael v
PostSubject: calibrating speedo ae 101   calibrating speedo ae 101 EmptyWed May 13, 2020 6:07 am
lads,is there a method of calibrating the speedo on a 93 corolla?
My speedo was always reading about 15-20 kmh slower than what i am actually doing.
Oringial wheels fitted,i swapped a 6 speed c160 box into the car and its still the same.
PostSubject: Re: calibrating speedo ae 101   calibrating speedo ae 101 EmptyThu May 14, 2020 1:34 pm
I had an issue like that once, I took off the needle and put it back on at the correct spot. If you remove the cluster and pop the plastic off, you can then carefully bend the needle so that it goes beyond the stop. Then, it will naturally come to it's own stop. keep in mind exactly where it stops, and then use a couple of flat blades to slowly wiggle the center of the needle up off the pin. Then simply rotate it 15-20 kmh and push it back on, and then lift it back over the stop.
» speedo
» speedo not working
» Corolla e10 ae101 digital speedo.
