Not a Corolla, sorta...... Prizm build in North Carolina EmptyMon Aug 21, 2023 2:26 am by motorsportbd
Not a Corolla, sorta...... Prizm build in North Carolina EmptyMon May 15, 2023 6:13 am by emmet.harten3
Not a Corolla, sorta...... Prizm build in North Carolina EmptyMon May 15, 2023 5:32 am by emmet.harten3
Not a Corolla, sorta...... Prizm build in North Carolina EmptyMon May 15, 2023 5:30 am by emmet.harten3
Not a Corolla, sorta...... Prizm build in North Carolina EmptyMon May 15, 2023 5:29 am by emmet.harten3
Not a Corolla, sorta...... Prizm build in North Carolina EmptySat Feb 11, 2023 2:08 am by emmet.harten3
Not a Corolla, sorta...... Prizm build in North Carolina EmptySat Feb 11, 2023 1:30 am by emmet.harten3
Not a Corolla, sorta...... Prizm build in North Carolina EmptySun Feb 05, 2023 1:53 pm by gold94corolla
Not a Corolla, sorta...... Prizm build in North Carolina EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
Not a Corolla, sorta...... Prizm build in North Carolina EmptyThu Dec 29, 2022 7:47 am by prnguy
Not a Corolla, sorta...... Prizm build in North Carolina EmptySun Sep 04, 2022 1:44 pm by kaitaiya
Not a Corolla, sorta...... Prizm build in North Carolina EmptySat Sep 03, 2022 12:36 pm by gold94corolla
Not a Corolla, sorta...... Prizm build in North Carolina EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
Not a Corolla, sorta...... Prizm build in North Carolina EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
Not a Corolla, sorta...... Prizm build in North Carolina EmptySat Jun 25, 2022 11:23 pm by Batezy11
Not a Corolla, sorta...... Prizm build in North Carolina I_vote_lcapNot a Corolla, sorta...... Prizm build in North Carolina I_voting_barNot a Corolla, sorta...... Prizm build in North Carolina I_vote_rcap
7AGPrizm
PostSubject: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyMon May 25, 2020 6:17 pm
What's up world?!?!  So I don't have a corolla anymore,  been looking around for a few years on and off.  I recently bought a Tacoma for $300, spent about $500 total including the purchase of the truck, sold it for it $3500 and found this Prizm for $250.  Reason it was so cheap,  4th and 5th gear were missing, basically not working.  So I picked up a verified 30K mile transmission for $300, bought a new clutch kit, flywheel, rear main and other gaskets to reseal the engine, new cv axles, new motor mounts, timing belt kit, with water pump and then I got new headlight assemblies, got all LED bulbs from Superbrightleds.com and put this car back together.  I did the rebuild in a couple of weekends,  one weekend to tear it apart, ordered parts, second weekend to put it all back together
the original plan was to take my time, clean up, shave and paint the engine bay, clean and paint the engine and transmission,  wire tuck and prep for a 7AGE conversion........  but since my main daily decided to blow the headgaskets,  I had to tear apart my car really quick and put it back together.  I will eventually go a turbo 7AGE engine, most likely 20valve too........
not my first time around Toyotas,  been playing with them since the 90s,  but here is the last AE101 I did.  a 94 Corolla with a NA 7AGE 16valve running on Microtech EFI back in the early 2000s'
Not a Corolla, sorta...... Prizm build in North Carolina JKDmdJ
Not a Corolla, sorta...... Prizm build in North Carolina UN8gUo
Not a Corolla, sorta...... Prizm build in North Carolina JpSjsv
Here are the pics from the facebook marketplace ad
Not a Corolla, sorta...... Prizm build in North Carolina OjZISb
Not a Corolla, sorta...... Prizm build in North Carolina 8oUBC8
Not a Corolla, sorta...... Prizm build in North Carolina STcqiT
Not a Corolla, sorta...... Prizm build in North Carolina LsrClQ
Here's when I went to go see it and buy it,  the dropping off to my shop and noticed how small it looks next to my Ram 1500.  Which is also the same Daily that blew headgaskets furious
Not a Corolla, sorta...... Prizm build in North Carolina Uql2FY
Not a Corolla, sorta...... Prizm build in North Carolina M9XSS2
Not a Corolla, sorta...... Prizm build in North Carolina UPyczU
Not a Corolla, sorta...... Prizm build in North Carolina XUmMSv
Not a Corolla, sorta...... Prizm build in North Carolina BLYAAN
Not a Corolla, sorta...... Prizm build in North Carolina RTRAbm
Picked up a used transmission with verified 30k miles on it
Not a Corolla, sorta...... Prizm build in North Carolina 8QWB6H
bought some new Federal Tires, went with 195/60/14 instead of 175/65/14 tires
Not a Corolla, sorta...... Prizm build in North Carolina UAUTcH
Not a Corolla, sorta...... Prizm build in North Carolina Ttmpar
Not a Corolla, sorta...... Prizm build in North Carolina 0Kg02o
Not a Corolla, sorta...... Prizm build in North Carolina C0aDFh
Not a Corolla, sorta...... Prizm build in North Carolina 04LSL7
Got the car jacked up and ready for tear down
Not a Corolla, sorta...... Prizm build in North Carolina EOqdLc
Not a Corolla, sorta...... Prizm build in North Carolina R8tmbJ
Not a Corolla, sorta...... Prizm build in North Carolina 4PoY3n
Not a Corolla, sorta...... Prizm build in North Carolina ZZXF4y
Not a Corolla, sorta...... Prizm build in North Carolina Al92Gg
All Engine mounts were completely bad
Not a Corolla, sorta...... Prizm build in North Carolina HZb2YC
Removed the charcoal canister from the fuel filter bracket
Not a Corolla, sorta...... Prizm build in North Carolina S0VwYW
Not a Corolla, sorta...... Prizm build in North Carolina 7Ab2f7
Also removed the power steering,  just looped the lines for now.  I do have a rack I pulled out of the salvage yard to rebuild and convert to manual steering
Not a Corolla, sorta...... Prizm build in North Carolina 1K2Ukr
Glad I decided to do the timing belt while I had the engine out,  looks to be the original belt.....  I also replaced the water pump
Not a Corolla, sorta...... Prizm build in North Carolina PNpJwz
Not a Corolla, sorta...... Prizm build in North Carolina VdvRIM
Not a Corolla, sorta...... Prizm build in North Carolina 165teV
Not a Corolla, sorta...... Prizm build in North Carolina SUkVmS
Not a Corolla, sorta...... Prizm build in North Carolina RBQsQB
Not a Corolla, sorta...... Prizm build in North Carolina UU0J6i
Not a Corolla, sorta...... Prizm build in North Carolina SQh7wv
Not a Corolla, sorta...... Prizm build in North Carolina JWd4g1
Full tune-up done as well,  NGK plugs and wires. Intermotor distributor cap and rotor
Not a Corolla, sorta...... Prizm build in North Carolina Gaky43
New Flywheel and Clutch ready for the low mileage transmission
Not a Corolla, sorta...... Prizm build in North Carolina Z6U2v9
Not a Corolla, sorta...... Prizm build in North Carolina DLesht
New Throw Out Bearing
Not a Corolla, sorta...... Prizm build in North Carolina FX1aOL
Engine ready to go back in
Not a Corolla, sorta...... Prizm build in North Carolina A3KHzi
Not a Corolla, sorta...... Prizm build in North Carolina PhRTDC
Not a Corolla, sorta...... Prizm build in North Carolina Y2x4cL
She's in!!!!!
Not a Corolla, sorta...... Prizm build in North Carolina PmXeeJ
Not a Corolla, sorta...... Prizm build in North Carolina GjIEaR
Not a Corolla, sorta...... Prizm build in North Carolina Id9zji
Before and After,  I really wish I had more time to clean, prep and paint.
Not a Corolla, sorta...... Prizm build in North Carolina TpY9Gp
First tank of fresh 93 since she was on E before I took her apart
Not a Corolla, sorta...... Prizm build in North Carolina 4QF8AY
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyTue May 26, 2020 11:00 am
Welcome along! Great work fixing it up! Thanks for sharing the enjoyable pics
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyWed May 27, 2020 1:45 am
Where at in N.C.? I’m in Greensboro
7AGPrizm
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyWed May 27, 2020 2:42 am
gold94corolla, were you on Corolla Car Club forum back in the day? Screen name looks familiar.
kickfli12, I'm about a couple of hours from Greensboro in Coats
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyWed May 27, 2020 10:29 am
Yep! I've been around for.... 15 years or so? haha. The CCC forum is still up, but dead like most forums now thanks to social media.
7AGPrizm
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyWed May 27, 2020 10:45 am
Lol! Yeah, I was TE31Rolla back then, central Florida chapter member. That place got dead not long after I left the corolla game all together, but I'm having fun with the Prizm now and have some tricks up my sleeve
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyThu May 28, 2020 9:46 am
Glad you're having fun with the car! Must be neat having the "same" car again. I don't miss mine though, but it was kinda quick and zippy. CCC did die after something happened, I think there was some drama in Florida that split everyone up and then it was gone.
7AGPrizm
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyThu May 28, 2020 6:33 pm
I hate to admit, I was apart of that drama. But, it's the past, just wish I was smarter about things back then that could have prevented alot of drama. Lesson learned, it's a wash and it's a new day. But yeah, driving the Prizm the last week almost 2, have been fun. The car definitely brings back alot of memories. lol. Can't wait to really tear into this, but I have to wait till I get my truck running and back on the road
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyFri May 29, 2020 3:55 am
Ah yeah, I feel ya. I've had drama and stuff in the past that I'm not super proud of, but live and learn. Makes us better characters Smile
7AGPrizm
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyWed Jul 01, 2020 1:46 pm
Not a huge update,  between work and family life,  I haven't done much.  BUT!  I had a slow moment at work, doing my typical craigslist browsing and I see an ad for a estate auction,  I click on it and see a shit load of cars and tools along with house stuff and shop stuff as well.  The ad had a few MR2s a couple of FWD Corolla GTS' and a shit ton of classic cars, trucks, vans, etc........ anyways,  I'm there for the MR2s!  Lol.  So I walk in and I told my friend if I find a supercharged MR2, I'm gonna buy it.  He laughed and said I'm not that lucky, well,  I wish I would have made a bet, I walked in, I see the first row of MR2s,  first one I see is indeed a Supercharged MR2!  So after watching the first two MR2s get sold for $100 and $125,  the time came to the supercharged MR2,  they start the bid at $500, then dropped down to $100 and that's when I placed the bid, someone else jumped in and I was in a bidding war with him now grr  so back and forth a few times, I got the winning bid at $425!  More than what I originally wanted to spend, but still a steal at the same time.  Lol.  Oh and I did buy a second one for $125, so I can't complain, two MR2s for $550 plus 10% fees
So plans?  get the 4AGZE running,  once I know its running, has good compression, etc,  I'll remove it from the MR2, reseal the engine, clean it up, re-wire the harness and swap it into my Prizm.  It's definitely not gonna happen right away as I gotta get my Trucks engine rebuilt and running again,  then I can focus on the swap.  But between then and now,  I'll focus on getting the 4AGZE running and go from there
Parked away from everybody
Not a Corolla, sorta...... Prizm build in North Carolina FHJ5wp
There she is!  And yes I did bid on the Datsun truck,  no I didn't win  Sad
Not a Corolla, sorta...... Prizm build in North Carolina LY0Z6M
4AGZE!  The car only has 120k miles on it,  I'm thinking I can get this thing running before I pull it out and swap it into my Prizm  Twisted Evil
Not a Corolla, sorta...... Prizm build in North Carolina OTsaJ6
The two turds on the side of my house, my current car count is now 6, I wonder what my neighbors think?  Lol
Not a Corolla, sorta...... Prizm build in North Carolina ShhN6p
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyThu Jul 02, 2020 10:40 am
lol, nice find on 2 MR2 junkpiles for $550 haha. Good luck!
7AGPrizm
PostSubject: Re: Not a Corolla, sorta...... Prizm build in North Carolina   Not a Corolla, sorta...... Prizm build in North Carolina EmptyThu Jul 02, 2020 2:34 pm
thanks!  wish I could have bought more, but I got into the bidding war with the GZE car.  lol
In other news,  my short shifter and shifter bushings came in, now just need to finish up a customer car I have so I can use the space to get these installed.
Not a Corolla, sorta...... Prizm build in North Carolina 2Q9moD
Adjusted the rear springs,  sits better now than before cause it was saggin bad
Not a Corolla, sorta...... Prizm build in North Carolina NcKBl6
» 2ZZ-GE 7 Speed LSD Corolla build
» Ae101 Levin front converted Geo Prizm 1997 Daily Driver Build Thread CA, USA
» What's this!? Aaron's 93 Corolla Build Thread
» 93 Toyota Corolla DX (Slow Build)
» 95 Corolla Build
