Installing Cluster Dimmer EmptyMon Aug 21, 2023 2:26 am by motorsportbd
Installing Cluster Dimmer EmptyMon May 15, 2023 6:13 am by emmet.harten3
Installing Cluster Dimmer EmptyMon May 15, 2023 5:32 am by emmet.harten3
Installing Cluster Dimmer EmptyMon May 15, 2023 5:30 am by emmet.harten3
Installing Cluster Dimmer EmptyMon May 15, 2023 5:29 am by emmet.harten3
Installing Cluster Dimmer EmptySat Feb 11, 2023 2:08 am by emmet.harten3
Installing Cluster Dimmer EmptySat Feb 11, 2023 1:30 am by emmet.harten3
Installing Cluster Dimmer EmptySun Feb 05, 2023 1:53 pm by gold94corolla
Installing Cluster Dimmer EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
Installing Cluster Dimmer EmptyThu Dec 29, 2022 7:47 am by prnguy
Installing Cluster Dimmer EmptySun Sep 04, 2022 1:44 pm by kaitaiya
Installing Cluster Dimmer EmptySat Sep 03, 2022 12:36 pm by gold94corolla
Installing Cluster Dimmer EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
Installing Cluster Dimmer EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
Installing Cluster Dimmer EmptySat Jun 25, 2022 11:23 pm by Batezy11
Installing Cluster Dimmer I_vote_lcapInstalling Cluster Dimmer I_voting_barInstalling Cluster Dimmer I_vote_rcap
GT2OV
GT2OV
PostSubject: Installing Cluster Dimmer   Installing Cluster Dimmer EmptyThu Feb 16, 2012 3:32 pm
Hey guys, new to the forum here.
So my corolla came with a coin slot in the place where the dimmer for the instrument display should be
got hold of a dimmer for the car, popped it into place, but cant seem to find the plug to hook it into.
Anyone done this before or know what I need to do?
Also: Anyone know of any shops in NZ that sell LED kits to replace the bulbs?
Cheers
PostSubject: Re: Installing Cluster Dimmer   Installing Cluster Dimmer EmptyThu Feb 16, 2012 6:38 pm
Hey LEDs will counter the dimmer's functionality, since they need a different approach. However fitting the dimmer won't be hard. You have to look for a small connector with a wire looped from one pin to the other... Smile
GT2OV
GT2OV
PostSubject: Re: Installing Cluster Dimmer   Installing Cluster Dimmer EmptyThu Feb 16, 2012 7:42 pm
The plug that goes into the back of the dimmer was missing (not sure if it was ever there), so I cut the 12V line to the 3 dash lights and soldered the dimmer in between.
What needs to be done to replace the dash bulbs with LEDs?
PostSubject: Re: Installing Cluster Dimmer   Installing Cluster Dimmer EmptyFri Feb 17, 2012 12:45 am
You need to recalculate the different resistances of the dimmer switch and make sure you don't blow your LED's...
PostSubject: Re: Installing Cluster Dimmer   Installing Cluster Dimmer EmptyFri Feb 17, 2012 5:32 pm
i also didn't have the connecter in my 2.0D but i managed to solder the direct current wires going to the meter in the switch.and about the led s the dimmer works but it will not work the way you're expecting.ive tried it on my led meter it didn't give much difference in the lighting.if u want my advice it change the bulbs and put it different color bulbs
» BZ Touring White Auto Cluster
» Need Help Installing Key Light
» help with ae100 cluster
» Cluster
