PROBLEM of defrost  EmptyMon Aug 21, 2023 2:26 am by motorsportbd
PROBLEM of defrost  EmptyMon May 15, 2023 6:13 am by emmet.harten3
PROBLEM of defrost  EmptyMon May 15, 2023 5:32 am by emmet.harten3
PROBLEM of defrost  EmptyMon May 15, 2023 5:30 am by emmet.harten3
PROBLEM of defrost  EmptyMon May 15, 2023 5:29 am by emmet.harten3
PROBLEM of defrost  EmptySat Feb 11, 2023 2:08 am by emmet.harten3
PROBLEM of defrost  EmptySat Feb 11, 2023 1:30 am by emmet.harten3
PROBLEM of defrost  EmptySun Feb 05, 2023 1:53 pm by gold94corolla
PROBLEM of defrost  EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
PROBLEM of defrost  EmptyThu Dec 29, 2022 7:47 am by prnguy
PROBLEM of defrost  EmptySun Sep 04, 2022 1:44 pm by kaitaiya
PROBLEM of defrost  EmptySat Sep 03, 2022 12:36 pm by gold94corolla
PROBLEM of defrost  EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
PROBLEM of defrost  EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
PROBLEM of defrost  EmptySat Jun 25, 2022 11:23 pm by Batezy11
In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
PROBLEM of defrost  I_vote_lcapPROBLEM of defrost  I_voting_barPROBLEM of defrost  I_vote_rcap
 PROBLEM of defrost
Kevin974
Kevin974
PostSubject: PROBLEM of defrost    PROBLEM of defrost  EmptyThu Apr 19, 2012 7:51 pm
Hello all
I have a problem with my defrost!
He could not work, no wires running
But when I press the button light is the flash button that
It could be the fuse?
thank you
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptyFri Apr 20, 2012 10:58 pm
have you tried changing the fuse its the first fuse in the driver side kick panel i also had that problem changing the fuse solved i all
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptyFri Apr 20, 2012 11:50 pm
Mines recently stopped working. It's been raining the past few days, I'm gonna check the fuses, then if not I'll pull off the rear paneling and check the wires leading to the rear windshield.
Kevin974
Kevin974
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptySat Apr 21, 2012 2:40 am
Thanks
look fuse
Tomorrow Wink (Y)
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptySat Apr 21, 2012 4:29 am
the defogger fuse is at the top right fuse and if the fuse is ok then the metal plate attached to the window has come off
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptySat Apr 21, 2012 4:53 am
my defogger plates has come off from the window so instead off the defoger i use my rear air purifier the air coming from that clears all the fog from the window
Kevin974
Kevin974
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptySat Apr 21, 2012 5:15 am
I is not perificateur in my car :/
I'd look tomorrow: D
HS ON: Flashing your bumper is same that me , no ?
You have or buy? thank you
HS OFF
PostSubject: Re: PROBLEM of defrost    PROBLEM of defrost  EmptySat Apr 21, 2012 9:09 pm
i didnt understand what u wrote bro
PROBLEM of defrost
» Rear Windshield Defrost
» econometer problem. HELP
» ABS PROBLEM
» rev problem
» Problem with my polo,Help please.
