battery relocation EmptyMon Aug 21, 2023 2:26 am by motorsportbd
battery relocation EmptyMon May 15, 2023 6:13 am by emmet.harten3
battery relocation EmptyMon May 15, 2023 5:32 am by emmet.harten3
battery relocation EmptyMon May 15, 2023 5:30 am by emmet.harten3
battery relocation EmptyMon May 15, 2023 5:29 am by emmet.harten3
battery relocation EmptySat Feb 11, 2023 2:08 am by emmet.harten3
battery relocation EmptySat Feb 11, 2023 1:30 am by emmet.harten3
battery relocation EmptySun Feb 05, 2023 1:53 pm by gold94corolla
battery relocation EmptyFri Jan 20, 2023 1:49 pm by gold94corolla
battery relocation EmptyThu Dec 29, 2022 7:47 am by prnguy
battery relocation EmptySun Sep 04, 2022 1:44 pm by kaitaiya
battery relocation EmptySat Sep 03, 2022 12:36 pm by gold94corolla
battery relocation EmptyFri Jul 22, 2022 3:15 pm by Yunmiliautoparts
battery relocation EmptyFri Jul 22, 2022 3:12 pm by Yunmiliautoparts
battery relocation EmptySat Jun 25, 2022 11:23 pm by Batezy11
In total there are 16 users online :: 0 Registered, 0 Hidden and 16 Guests :: 1 Bot
battery relocation I_vote_lcapbattery relocation I_voting_barbattery relocation I_vote_rcap
 battery relocation
PostSubject: battery relocation   battery relocation EmptyThu Aug 23, 2012 8:32 am
hi has anybody on here done a battery relocation i.e from under the bonnet to the rear end pics and diagrams and any info very appreciated thanks
PostSubject: Re: battery relocation   battery relocation EmptyFri Aug 24, 2012 3:01 am
i have done it,
need 2 thick long cables (1 live, 1 earth), Battery terminals, Battery cable ends,
Step 1. Disconnect and pull the battery out of the car (10mm)
Step 2. Pull battery tray (12mm and 10mm)
Step 3. Run 2 whole length of cables leaving 2 feet of extra cable in your boot.
I opted to run the positive connection underneath the car following the fuel and brake lines.
Step 4. Mount the battery box in the trunk.
Step 5. Cut a section of the 2 feet you left in the trunk for a ground cable. Strip, and Crimp one connector on each of the wires. Then Strip and mount the terminals on the other end of the wire to lead to the battery. (Note in order to crimp those BEASTLY 2 Gauge Ring Connectors you should use a Vice!)
Step 6. Ground the negative cable to the bolt in the rear quarter panel. (10mm) The positive should be connected to the positive terminal in the engine bay by taking off the 12mm nut from the terminal and fitting the ring connector in there.
Step 7a. Secure the terminals (Ground cable first)
Step 7b. As soon as you get your battery connected your trunk light SHOULD turn on. If it did, go ahead and start the car to soak up the awesome-ness of having a relocated battery.
PostSubject: Re: battery relocation   battery relocation EmptyFri Aug 24, 2012 3:07 am
thanks for that i will crack on with that as soon as i get chance and the extra funds its the mot tax and insurance this month so probably wont be much progress Crying or Very sad
PostSubject: Re: battery relocation   battery relocation EmptyFri Aug 24, 2012 9:03 pm
Mayb I should take some pics of mine??
PostSubject: Re: battery relocation   battery relocation EmptyFri Aug 24, 2012 10:02 pm
would be great if you could mate.
PostSubject: Re: battery relocation   battery relocation EmptyFri Aug 24, 2012 10:39 pm
Also check through my build iv done the same
battery relocation
