| Amplifier Ground | |
affliKtd Member
Posts : 99 Reputation : 0 Join date : 2012-09-21 Age : 109 Location : NZ
 | Subject: Amplifier Ground Fri Sep 21, 2012 7:49 am | |
| Hey all, I've got a New Zealand new AE101 1.6GL sedan. I've had previous attempts at installing an amplifier in my car, yet no matter where I ground it, I always get HUGE amounts of feedback. Just wondering if anyone has any ideas on where to ground/mount my amplifier, taking into consideration that there's barely any room in my boot due to the fact that it's usually filled up with bikes, and would like it to be hidden due to the large amount of dodgy people that live around me!  Cheers. | |
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:21 am | |
| how about on the back of the seats? | |
affliKtd Member
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:24 am | |
| Unfortunately I can't as when my bike is in the boot I also have to put the back seat down  the only place I've found that works really well is under the driver/passenger seat. Although from there I get stuck as I'm not sure where to run the ground to. Thinking about running it to the strut tower as it's only like 1m away, but unsure how it would work. | |
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:26 am | |
| what about under the carpet and near the gear shifter or handbrake lever? | |
affliKtd Member
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:28 am | |
| Do you know of any bolts that would be okay to mount it to? I would rather avoid drilling holes in my tunnel  . The bolts I've tried to mount it to before have always had plastic insulating them :/ | |
Hiro Super Member
Posts : 544 Reputation : 16 Join date : 2012-04-27 Age : 39 Location : Newcastle, Australia
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:30 am | |
| My amp is in the boot and I grounded it to one of the rear suspension strut top-hat bolts, works fine and doesn't get in the way of folding the seats down etc (the sub box does though  ) | |
affliKtd Member
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:34 am | |
| Yeah that's where I was thinking about mounting the ground to, it shouldn't affect the grounding too much coming from under the seat, right? I know it should be as short as possible, but it's only a 4 x 65w RMS amplifier. | |
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:37 am | |
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:39 am | |
| what about under the seat bolts? | |
affliKtd Member
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 8:40 am | |
| I've tried like every single seat bolt and it just gives a ton of feedback, not nice at all! | |
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 9:16 am | |
| Are you sure it has a good ground? Did you sand to bare metal? Maybe there's something wrong with your amp, or maybe even the chassis ground. | |
knite Supreme Member!
Posts : 1102 Reputation : 15 Join date : 2012-07-08 Location : Kent
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 10:19 am | |
| what kind of noise r u getting? do u have a vid? it could be alternator noise in which case u would need one of these. you can tell if its this as the noise changes to higher pitch when revving the car. click here u can buy them from halfords for about £5 as u only need 1. hope that helps  | |
affliKtd Member
 | Subject: Re: Amplifier Ground Fri Sep 21, 2012 12:46 pm | |
| Sanded back to bare metal each time. It's just the location as I've tried 4 different amps. I know for a fact that it's alternator whine. | |
 | Subject: Re: Amplifier Ground Sat Sep 22, 2012 5:01 am | |
| - affliKtd wrote:
- Sanded back to bare metal each time. It's just the location as I've tried 4 different amps. I know for a fact that it's alternator whine.
so it is alternator whine? or did u miss type? | |
affliKtd Member
 | Subject: Re: Amplifier Ground Sun Sep 23, 2012 4:12 pm | |
| Yeah it definitely is alternator whine | |
 | Subject: Re: Amplifier Ground Mon Sep 24, 2012 5:10 am | |
| then get a suppressor that bolts on to the alternator they are only about £5 from halfords and they just slide onto the alternator bolts so are easy to it. | |
 | Subject: Re: Amplifier Ground  | |
